606 A460
old blue
Racerdad96
606 A460  Empty 606 A460
Post  Racerdad96 April 21st 2016, 11:06 am
A460 CNC 360cc heads from TEA, 1.73 rockers, A460 Block 4.630 bore, Eagle 6.700 rods, Eagle 4.500 crank, Lem Evans spec camshaft, Trickflow intake, Quick fuel 1450 carb.
Thanks to Lem for the camshaft and Kaase oil pump.
Thanks to Oakley Motorsports for the 1450, jomar powercone, tuning the carb, and dyno services.
Racerdad96
Racerdad96
606 A460  Empty Re: 606 A460
Post  Lem Evans April 21st 2016, 11:25 am
Do you have a photobucket account?
606 A460  Empty Dyno sheet
Post  Racerdad96 April 21st 2016, 11:36 am
https://2img.net/h/i1152.photobucket.com/albums/p497/shedger/Mobile%20Uploads/20160420_112708_zps4a1x2xxh.jpg
Racerdad96
Racerdad96
Post  Lem Evans April 21st 2016, 11:39 am
606 A460  20160420_112708_zps4a1x2xxh
Post  windsor April 21st 2016, 11:41 am
Woo doggy. Nice piece!
Compression ratio?
Post  Racerdad96 April 21st 2016, 11:45 am
Thanks. 13.8-1 Arias pistons
Racerdad96
Racerdad96
Post  old blue April 21st 2016, 12:47 pm
Yea man, thats some nice numbers, that baby is going to pull
old blue
old blue
Post  gmsmkr April 21st 2016, 12:50 pm
Makin power
gmsmkr
gmsmkr
Post  windsor May 1st 2016, 2:45 am
That's a nice power peak at only 7000 rpm Cool
What kind of ride is this going to be bolted into?
Post  Racerdad96 May 1st 2016, 10:49 am
windsor wrote:That's a nice power peak at only 7000 rpm Cool
It is going in a dragster.
Racerdad96
Racerdad96
Post  68formalGT May 1st 2016, 11:50 am
Nice numbers!!! Did you have to do much to the carb?
Post  Racerdad96 May 1st 2016, 12:01 pm
68formalGT wrote:Nice numbers!!! Did you have to do much to the carb?
No Phillip Oakley just changed a few jets. Other than that it is straight out of the box.
Racerdad96
Racerdad96
Post  68formalGT May 1st 2016, 12:13 pm
I haven't looked at a lot of dyno sheets but the A/F ratio looks pretty steady through the pull, is that about as good as it gets or is there room for improvement?
Post  Racerdad96 May 1st 2016, 12:20 pm
This is the first engine I have put on the dyno. Phillip told me he likes the A/F ratio a little fat on the low end and he has it clean up some as the rpm goes up.
I find it best to listen to people with way more knowledge then I have.
Racerdad96
Racerdad96
Post  John Myrick May 1st 2016, 1:55 pm
Oakley is very good at getting the QFT carbs working properly
Post  crittersf1 May 4th 2016, 2:45 pm
How much more do you think it would pick up with 2 carbs?
crittersf1
crittersf1
Post  68formalGT May 4th 2016, 3:00 pm
crittersf1 wrote:How much more do you think it would pick up with 2 carbs?
Keith did his build with the tunnel ram and single and duel carbs before putting the toilets on.
https://www.429-460.com/t16558-keith-fulp-s-618-a-head-interceptor
Post  Racerdad96 May 4th 2016, 4:01 pm
I don't have a clue.
Racerdad96
Racerdad96
Post  windsor May 30th 2016, 8:27 am
Are you running steel valves or titanium?
Post  Racerdad96 May 30th 2016, 9:34 am
windsor wrote:Are you running steel valves or titanium?
I am running steel valves.
Racerdad96
Racerdad96
Post  windsor May 30th 2016, 10:35 am
Copy. Thanks for all the info on your build. Good stuff.
