31 spline 9" "take a look at it"
+6
crittersf1
Gregaust
10 posters
31 spline 9" "take a look at it" Empty 31 spline 9" "take a look at it"
Post  460bronco May 14th 2016, 5:42 pm
31 spline 9" "take a look at it" Image_zpsu4v82pia
Take a gander at this pic and let me know how awesome y'all think this was!
523 making some ponies now!
460bronco
460bronco
31 spline 9" "take a look at it" Empty Re: 31 spline 9" "take a look at it"
Post  billandlori May 14th 2016, 10:14 pm
Big power!!
No picture of the quarter panels lol!! Hope it didn't damage too much stuff!!
Bill
Post  Mike R May 14th 2016, 10:53 pm
affraid cheers cheers
Post  Gregaust May 15th 2016, 4:04 am
Oh Dear ... Not Good . Those axles ever been heated or tacks of weld on the bearing retainers ?? Sort of odd they both broke exactly the same Sad
Gregaust
Post  460bronco May 15th 2016, 7:08 am
I had new wheel bearings installed a few years ago, and I'm almost certain the guy cut the old bearings off with a torch..... I was pretty upset at the time. They said everything would be fine and that's how "they always do it".
Axle on the left broke about a year ago in a mud drag pit. Truck ended up on its roof....
After many gremlins, I finally got the truck back going and decided to ride to the local 1/8 mile drag strip. 1st pass, when I shifted to second gear, the engine ran away and the truck immediately went in a spin to the right. Truck did 2 360's before slamming into the guard rail... Luckily with the rear bumper.
The right rear quarter panel got folded under the truck before the tire was ejected. The tire kept going down the track and went through the traps about 80mph!!!!!
----what kind of axles do I need?
523" -SCJ heads ~600-650hp with occasional 2-300 shot.
Truck weighs 4800lbs, 4.56 gears and 37" tires.
460bronco
460bronco
Post  jbozzelle May 15th 2016, 10:47 am
I like Strange axles. Call them and they'll set you up with a good recommendation.
But any of the aftermarket stuff should be good. I'm sure there is a axle manufacturer out there that is familiar with the 4x4 and off road stuff and what it takes to stand up to the abuse...
Post  460bronco May 15th 2016, 11:09 am
Anybody seen factory 9" axles broken like this before??
460bronco
460bronco
Post  maverick May 15th 2016, 1:51 pm
Factory stuff....sure. Smack a lot of power to sticky track with big slicks...or a lot of power through giant heavy  mud tires...expect no less, no matter if the axles were heated or not.  Good aftermerket axles are a bargain for anybody making power, not to mention the safety factor.  My wimpy Maverick has 40 spline Strange stuff in it because I've broken driveline parts before, and you NEVER break just ONE part.
I broke the input shaft off a 9" pinion gear once. It tore up everything from the carrier to the planetaries. $$$$$.
In your case, $500 for a pair of axles would go a long way toward peace of mind.
Post  FalconEh May 15th 2016, 8:38 pm
maverick wrote:Factory stuff....sure. Smack a lot of power to sticky track with big slicks...or a lot of power through giant heavy  mud tires...expect no less, no matter if the axles were heated or not.  Good aftermerket axles are a bargain for anybody making power, not to mention the safety factor.  My wimpy Maverick has 40 spline Strange stuff in it because I've broken driveline parts before, and you NEVER break just ONE part.
^^^^^^^^^^^ Same, except for the wimpy Maverick part... Fords answer for the baddest of the time 429 SCJ etc. they held up well but when you increase the HP, add NOS. double + the wheel weight , or generally hook it with more power and they break.
Post  460bronco May 15th 2016, 9:48 pm
Maverick- do you have your 40 splines in a 3.25" case?
460bronco
460bronco
Post  crittersf1 May 19th 2016, 11:59 am
I run 35 spline Yukons in mine
crittersf1
crittersf1
Post  maverick May 19th 2016, 5:56 pm
460bronco wrote:Maverick-  do you have your 40 splines in a 3.25" case?
It's a big bearing Strange aluminum carrier.
Post  460bronco May 20th 2016, 7:02 am
Thanks for the responses guys!  I'm probably going to go the 35 spline route.  I sent Strange a message and they recommended the street/strip 35 spline for the application.
460bronco
460bronco
Post  IDT-572 May 20th 2016, 2:16 pm
I have never seen one break in the biggest diameter part of the axel like that unless it hit something. I always see them twist of right at the spool or within a ft of it.
Post  70FB May 20th 2016, 4:02 pm
I had to replace my Strange 35s due to my housing was flexing. We stiffened it up and for the piece of mind I went back with the gundrilled 40s. Overkill on my car but worth it.
70FB
70FB
Post  460bronco May 20th 2016, 5:52 pm
IDT-572 wrote:I have never seen one break in the biggest diameter part of the axel like that unless it hit something. I always see them twist of right at the spool or within a ft of it.
I think it's an odd spot too Blake...  Since both of my axles broke in the same spot (and a weird one at that), I'm gonna have to say it probably stemmed from an error in wheel bearing installation..... Or the fact that these axles are about 38 years old.
460bronco
460bronco
Post  FalconEh May 20th 2016, 6:22 pm
I agree with Blake that with a spool and slicks on a mostly level surface the axles usually snip the splines off or are within a foot, but with the heavier big tire big power trucks, many are not spooled, and due to wheeling on uneven surfaces, side hooking the outside of tires on rocks/roots (TSL bogger example) often tend to break closer to the flanges many times studs ripped off too. Other things I have seen is trucks that were seemingly bulletproof moved from 35"-37", 37"-40", 40"-44" etc and became grenades constantly breaking parts. Many 40" and over are running 1-3 Ton stuff that is cyro'd or Rockwells and usually spit the stub shafts, and hubs. I am not saying that a bearing installation couldn't have contributed, but many years of hard service definitely did, I have drawn a straight line down stock axles with a paint marker and you would be surprised at how much twist some hard service can create.
