P51 vacuum engine
P51 vacuum engine
My neighbor had Phillip Oakley build an engine for his mud drag truck. Rules allow an aluminum head that will function with factory cast intake and exhaust manifolds. The P's were the best choice. I don't have all of the spec's because it's not mine, but whatever Mr Oakley wants it offer is up to him. All I know for sure is that they used my old A block and 4.5" Crower crank. This engine is for a vac limited class in mud drags and after seeing it run this weekend it's darn nasty.
schmitty- Posts : 4538
Re: P51 vacuum engine
Get some!
Sweet Deal!! Kevin's going to break some hearts with that set up!!
68formalGT- Posts : 865
He has already broken a rear end and a front lockout hub. Hearts are next.
^^^^LOL fid the weak point, fix it then go after their's.
Oh and if you have any of that wool left from those sheep Freelander might be up for trading some parts.
» Engine Vacuum and Tune Questions
» 514ci BLUE THUNDER HEADED ENGINE & bbf parts,and engine for sale
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
» 653 CI Thor Headed big block Ford engine / ENGINE SOLD THANKS!!!!!
