71 429 cobra jet engine - piston identification
Definitely shows "230" not .030.
Sorry, this ^^^^ is in response to an earlier post re: identify the current pistons installed in my '71 429cj engine.
TRW 98 230 shows on the underside of the installed pistons. Trying to confirm what they are... Cheers
Pastel Blue- Posts : 47
Re: 71 429 cobra jet engine - piston identification
That number is the forging blank number. It is simply the one used to make that and other similar size and style pistons. OEM TRW supplied pistons should have the Ford part number stamped on the flat top. Same with the TRW replacement except it would have a TRW number. The OEM piston should be a flat top with valve relief cut out only. 1.040 wrist pin diameter and pressed pin application. 5/64 x 5/64 x 3/16 ring package.
gt350hr- Posts : 662
gt350hr wrote:That number is the forging blank number. It is simply the one used to make that and other similar size and style pistons. OEM TRW supplied pistons should have the Ford part number stamped on the flat top. Same with the TRW replacement except it would have a TRW number. The OEM piston should be a flat top with valve relief cut out only. 1.040 wrist pin diameter and pressed pin application. 5/64 x 5/64 x 3/16 ring package.
Thanks GT. Makes sense. I was undecided if I was going to remove the heads before taking to the machine shop, now as I investigate and learn more about the engine, I will remove the heads to see what pistons these are. Does make it easier to load and take to the machine shop anyway...
To ADMIN: I really wish I could load some pictures on this page, would be helpful, especially for me when asking questions... is this possible???
You need to get an account with a picture host like www.photobucket.com
And post links to the pics
Thanks. I do have a Photobucket setup, will look to utilize. I saw some pictures on some of the responses here (no apparent link to an offsite hosting service); that is why I asked.
» '71 429 cobra jet engine - piston identification?
» Engine Identification
» Engine identification help please
» engine casting identification
» PLEASE POST PICS OF YOUR ENGINES !!
