Tubes no Tubes
Tore
Tubes no Tubes
How many of your guys run without tubes??? DO you notice the sidewall breaking down any quicker without the tubes??
Pros and cons???
Thanks Tore
Pros and cons???
Thanks Tore
Tore- Posts : 865
Re: Tubes no Tubes
If your car is heavy, tubes may be a big help in both hook and tire survival. I don't use them but my heap isn't very heavy, either.
Without tubes your slicks will probably leak down some. Not a big deal at the track but storing the car will probably mean frequently adding air or keeping the car off the ground. Coating the inside of the tire with dish soap before mounting will help minimize air loss.
Fwiw, Hoosiers seem to hold air the best...but I wouldn't choose a tire just for that reason.
maverick- BBF CONTRIBUTOR
Re: Tubes no Tubes
I will never run without tubes again. I've did all the soap tricks and glue on the screws etc....and they always leaked down! The older they get the faster they leak! My experience is with M/T and good year though
Re: Tubes no Tubes
The 32x16 Hoosiers currently on my car are absolutely the best I've seen at holding air. I race the car with 7.5 psi in the slicks. The car sat in the garage for over 2 months and still had 7 psi in 'em....no soap, no sealer, no tubes.
Re: Tubes no Tubes
I've always heard they were far better at holding air than the others. I may try some if I ever have any trouble with the M/T but they sure do a good job,with tubes!maverick wrote:The 32x16 Hoosiers currently on my car are absolutely the best I've seen at holding air. I race the car with 7.5 psi in the slicks. The car sat in the garage for over 2 months and still had 7 psi in 'em....no soap, no sealer, no tubes.
Re: Tubes no Tubes
cool40 wrote:I've always heard they were far better at holding air than the others. I may try some if I ever have any trouble with the M/T but they sure do a good job,with tubes!maverick wrote:The 32x16 Hoosiers currently on my car are absolutely the best I've seen at holding air. I race the car with 7.5 psi in the slicks. The car sat in the garage for over 2 months and still had 7 psi in 'em....no soap, no sealer, no tubes.
Don't go fixin' stuff that works!
Re: Tubes no Tubes
No tubes, and,,,,,,,,,,,,,,,,, I have a set of soaped M/T's that hold air better than most peoples trailer tires.
Curt- Posts : 2791
Re: Tubes no Tubes
I ran tubes until I had a valve stem ripped out of one in the 3rd round of a race about 20 years ago. Never ran them since!
BigDave65- Posts : 567
Re: Tubes no Tubes
I've ran tubes and ran w/o .Ive always had good luck w/dish soap in the ones w/o.The new Toyo's I have on Tweety now don't have tubes or dish soap .Best slick I have ever owned.w/o leaks
Re: Tubes no Tubes
Well I bought tubes and new tires will see how it works.
Tks Guys Tore
Tks Guys Tore
Tore- Posts : 865
Re: Tubes no Tubes
Tubes, with wheels screwed and a generous helping of talc powder, it seems most of the tube failures I was witness to didn't do one or the other.
FalconEh- Posts : 1448
» thank god for tubes....
» M/T tubes
» how do people feel about torque tubes???? 18 inch
» Needed 14/32/15 racing tubes,near Indiana if possible
» Tubes & slicks
» M/T tubes
» Tubes & slicks
