25.1E ------- 64 Fairlane
+45
nitrous.f
Goldylox_fairlane
Bill Heard
wickettoby1
litshoot
rbro460
774 Super Street
drksyde64
ssurles268
pmrphil
D. Sea
514Fox87
Tomasw
maverick532
Wayne Pearce
slurm
AZFairlane
Race Ready Fabrications
larry552
gmsmkr
7.5L1985GT
Mustang-junky
514F-1
whitefield
jeffgfg
QKiss
49 posters
Page 12 of 13 Previous  1, 2, 3 ... , 11, 12, 13  Next
25.1E ------- 64 Fairlane - Page 12 Empty Re: 25.1E ------- 64 Fairlane
Post  Goldylox_fairlane June 9th 2020, 12:15 pm
Very Nice! Good to see!
Goldylox_fairlane
Post  wickettoby1 June 9th 2020, 7:15 pm
You killed it with this build!!!!!
wickettoby1
Post  Mark Miller June 9th 2020, 11:46 pm
QKiss wrote:25.1E ------- 64 Fairlane - Page 12 Img_2241
Finally ran out of excuses.Time to go to the track.
25.1E ------- 64 Fairlane - Page 12 Img_2240
A few shots around the car.
25.1E ------- 64 Fairlane - Page 12 Img_2238
25.1E ------- 64 Fairlane - Page 12 Img_2236[/url]
The aluminum hood was kicking my butt so we got it close and cleaned it up with a little bond then wrapped it with a carbon fiber skin.
25.1E ------- 64 Fairlane - Page 12 Img_2235
Till I have more time this winter to mess with the hood and blister a temporary scoop was made with some scrap lexan lying around the shop and it happened to be smoked --- came out pretty cool. Cool
25.1E ------- 64 Fairlane - Page 12 Img_2237
My wife said I have to put a picture of me in here. The first pass after the moderate  licensing was an 8.67 @ 157.94 MPH
Two words sum this up Bad Ass!! Smile
QtrWarrior, Mark Miller, hbstang, Colt Macara and nedceifus like this post
Post  QKiss June 10th 2020, 12:41 am
Thanks guys
QKiss
Location : Nor Cal -- Fortuna behind the Redwood curtian
Colt Macara likes this post
Post  69F100 June 23rd 2020, 11:41 am
Great looking car the hood looks good just as it is
Post  Curt June 23rd 2020, 7:29 pm
Love it!
Post  QKiss July 30th 2020, 11:04 pm
Had an intermtent electrical problem with the trans brake. Found a broken wire. Haven't had a chance to make any tuneup changes. Best performance to date 8.58 @ 160.44 MPH.
QKiss
Wayne Pearce, Mark Miller, Bill Heard and hbstang like this post
Post  litshoot September 4th 2020, 8:57 pm
Donyou have an idea of about how much tube actually went into this build. I'm thinking 25.2 cage, but i domt know how much material to buy. Thinking the majority will be upsized to 1 5/8 for structure and simplicity. Does 25.1 specify details on fromt or rear of vehicle as I'm looking for input was told the book will give ideas and 25.2 shows nothing. Thanks and awesome build.
litshoot
Post  QKiss September 6th 2020, 10:58 pm
litshoot;
      Do you have the SFI 25.2 spec? The individual Specs booklet of about 20 pages are available from SFI for about $40.00 each. 25.1 is for 6.00 second cars 2800 Lbs. Max. 25.2 is for 6.00 second cars 3200 Lbs. max. The NHRA Tech boys lean towards the 25.2 as running larger alcohol Fuel tanks -- Blowers -- and related support equipment easily puts you over the 2800 Lbs. max of 25.1. There is more tubing in the 25.2.There are 7 different size tubes for these Specs sooooo??? All of the SFI specs only address the Drivers compartment area. From the Firewall forwarding the main hoop rearward you need to refer back to the regular NHRA rulebook.
Q Kiss
QKiss
litshoot likes this post
Post  litshoot September 7th 2020, 11:17 am
Yes I have the 25.2 does that weight included driver. I had started the idea of a mostly street build that would evolve, but wanted to make sure everything was inline to build it. I was planning on using more 1 5/8 because you can go oversized, 100 foot 1.5 vs 1 5/8 is only 33 pounds more overall and simplify the tools and materials needed. I was making a 10 point as close to 25.2 specs as I could so in future retrofit will be adding bars with exception of seatbelts bar needing to be changed for funny car cage mounting. Just trying to find an idea of how much material goes in. Original thought had. Been about 140 feet of 1 5/8, 100 feet of 1.5 a piece of 1 1/8, 40 feet of 1 inch, a section fo 3/4, and disnt find a number for how much 1 1/4 I would need.
litshoot
Post  QKiss September 23rd 2020, 10:13 am
Back from vacation and just read your post. Could not find anything in the rules that specifically state the weight includes driver. I would be very surprised if it did not include driver. If I were that close that driver wieght made the difference I would go to the next higher spec.
    Aircraft Spruce www.aircraftspruce.com has a catalog of parts that cater to the home build aircraft hobby. They sell 4130 tube by the foot along with other materials in small quantities. This might help with the tubing issue.
Qkiss
Last edited by QKiss on September 23rd 2020, 10:18 am; edited 1 time in total (Reason for editing : web address)
QKiss
QtrWarrior likes this post
25.1E ------- 64 Fairlane - Page 12 Empty 4 link Brackets
Post  Goldylox_fairlane November 12th 2020, 12:23 pm
Just an incredible build!
I am also doing a fairlane with 2x3 tube. I am in the middle of figuring out 4 link brackets and I am stuck on the general design of the brackets. I noticed you made your own for this car. Could you please shed some light on the design process?
Goldylox_fairlane
Post  QKiss November 16th 2020, 1:04 pm
The rear end housing that I used was a Chris Alston fab 9 from a car that only had 6 passes on it with the housing brackets already installed. To keep the front bracket geometry the same that Chris designed into it I copied his layout from one of his front brackets. The Changes I made was for the mounting location to the chassis. Some of the suggestions I would make is use 1/2 inch holes laid out an arch to match your bar length to make it easier for location changes. Buy using 1/2 inch holes in the brackets they can be spaced 3/4 of an inch apart giving a finer adjustment than if you used 5/8 or 3/4 inch holes that would require wider hole spacing.  Rod ends are available with 3/4" shank and 1/2" ball hole.
25.1E ------- 64 Fairlane - Page 12 16711
25.1E ------- 64 Fairlane - Page 12 16611
QKiss
Goldylox_fairlane likes this post
Post  bruno February 16th 2021, 9:09 am
WOW !!! just an incredible build , great to see it complete
http://WWW.CKRME.COM
Post  QKiss March 22nd 2022, 11:44 am
For sale
    I have decided to sell the Fairlane. Came to the conclusion I'm a builder not a racer  and looking for the next project. Would like to sell the whole racing operation ----- Car -- trailer -&- Support equipment -------- This even includes fuel. You could race on the way home.Way to much to list.  Contact me for the 8 pages of included items.  Trailer is a 36' Featherlite gooseneck     Every thing for 125K
Steve Kioukis
slioukis@gmail.com or (Cell) 707-407-7181
QKiss
Post  QKiss March 22nd 2022, 11:59 am
Some shots of the Trailer.
25.1E ------- 64 Fairlane - Page 12 18310
25.1E ------- 64 Fairlane - Page 12 18410
25.1E ------- 64 Fairlane - Page 12 19210
25.1E ------- 64 Fairlane - Page 12 18910
25.1E ------- 64 Fairlane - Page 12 1901025.1E ------- 64 Fairlane - Page 12 13312
QKiss
Post  738drvr March 22nd 2022, 12:19 pm
Love the car. How much for the trailer?
Post  738drvr March 22nd 2022, 12:20 pm
How much work to get the car street legal?
Post  QKiss March 22nd 2022, 12:32 pm
738drvr wrote:Love the car. How much for the trailer?
      I will seperate but the car must go first.
QKiss
Post  QKiss March 22nd 2022, 12:45 pm
738drvr wrote:How much work to get the car street legal?
  Interesting you ask because the car has a clear title and a non-op with DMV. The only lights the car has now is tail lights. So what ever your State requires for lights and mufflers street tires ect--ect-- ect it would be need.
QKiss
Post  Goldylox_fairlane March 22nd 2022, 6:19 pm
Ohh man… what a set up. You don’t see too many cars built to this level of excellence.
Goldylox_fairlane
Post  QKiss March 22nd 2022, 8:25 pm
Goldylox_fairlane wrote:Ohh man… what a set up.  You don’t see too many cars built to this level of excellence.
Thank You ------- It is definetly going to be a real good deal for someone
QKiss
Post  Goldylox_fairlane March 22nd 2022, 10:00 pm
Yes . I agree.
That tool box fits perfectly in the trailer. I was thinking of doing something similar, Just never saw a snap on like that.
What model tool box is that?
Goldylox_fairlane
Post  QKiss March 23rd 2022, 12:16 pm
Goldylox_fairlane wrote:Yes . I agree.
The way I ended up with this box was looking for a snap-on box with the proper dimensions to fit and found it on crags list.
The reason for snap-on is to hold up better than the cheap boxes going down the road in the trailer.
25.1E ------- 64 Fairlane - Page 12 00210
25.1E ------- 64 Fairlane - Page 12 00310
QKiss
25.1E ------- 64 Fairlane - Page 12 Empty Still available
Post  QKiss August 31st 2022, 8:50 am
An update to let you all know the deal fell apart and the car is still available.
QKiss
