Need thoughts and suggestions
+6
70FB
Hardy
NITROUS FORD
tconnection
10 posters
With my combo on some things I'm kinda going with the way the wind blow. I need some thoughts on what the performance come of what I have going on at the moment. 580ci, a460 head mild port lowered short turn and port matched to gasket. 283/302@.050, 839/780lift, 114 lob sep, 1.76 glide, 6000 stall, 430gr, 29.5 tire, 2780lb. I have no nos on it right now. I'm wanting to Crack a 5 n/a. Any pros and cons?
tconnection- Posts : 866
Re: Need thoughts and suggestions
Cams a little big IMO
And I'd consider upgrading to some strait cut 1.80's in the trans
yea its going to break the 1.76 first gear in there!
NITROUS FORD- Posts : 63
I have nothing to offer besides what the others said, but that sounds like a 5.50 combination of not better
Hardy- Posts : 107
Sounds like a good combo for 5.49 index here. Then spray it for 4.90 index.
70FB- BBF CONTRIBUTOR
Hopefully the 1.76 gear will hold up. It's a JW Glide part number 92351v, good to 1800hp. Yea I was just wondering wondering about how this combo would kinda do. Some time or another I'm gonna stall down and go 1.80. But ain't a lot of cars gon to a higher tranny gear and lower rearend gear?
About what rpms it need to be spinned?
6000 may even be a little tight on the converter NA depending on some other things. Heads will determine where it's happy at but somewhere 72-7800 rpm I'd think.
Dang it! I do it every time I don't look at this cam card. I got the duration at .050 wrong. It's 283/302 not 292/304. Sorry bout that. Would this decrease in duration change things much?
Thanks for baring with me.
With a 4.5" stroke, thin, (light), rings will be necessary to make good power above 7,400 RPM without any crankcase vacuum.
.043 .043 3/16 diamond dome lateral gas ports.
I didn't mention that my carb is a qft, 1250.
You are running the same thing as me except I'm 3200 lb. and have P-51's flowing 435 cfm peak. 15:1 compression.
I have a 6100 converter and shift at 7200. 1.80 straight cuts. runs 5.40's.
tconnection wrote:With my combo on some things I'm kinda going with the way the wind blow. I need some thoughts on what the performance come of what I have going on at the moment. 580ci, a460 head mild port lowered short turn and port matched to gasket. 283/302@.050, 839/780lift, 114 lob sep, 1.76 glide, 6000 stall, 430gr, 29.5 tire, 2780lb. I have no nos on it right now. I'm wanting to Crack a 5 n/a. Any pros and cons?
Should run mid 5's easily at that weight.
» Street intake manifold for iron cj heads,suggestions, thoughts?
» thoughts on 514
» 572 thoughts??
» new by and looking for suggestions
» 429/460 Overheating Issue
» thoughts on 514
» 572 thoughts??
