Making a A460 block Badder!
+22
paperman
XF-66
torino501
kjett
ED468
JBR-3
BigDave65
Darrin Gorham
26 posters
Page 2 of 5
Page 2 of 5 • 1, 2, 3, 4, 5
Re: Making a A460 block Badder!
Home Alone Supper Time!
2" thick Ribeye & Garlic Bread!!
Frank Merkl- Posts : 1524
Well ,176 passes through the block with the boring bar Done !! Final cut of .007" in each hole in the morning after the boring bar and block has cooled ,to get to a final bore before honing of 4.603". Rum Time!!! Ye ha!!!
homemade horsepower! I have one of them old boarding bars Frank! Good machine I don't use often enough.
learnt a long time ago that if you want something done right ,learn how to do it your self (actually was told by a machine shop that if I didn't like the way they did my stuff maybe I should do it myself!!) , take your time , measure ,remeasure , recheck you math , rezero on the gauge blocks , then remeasure !!! any doubt remeasure !! on the boring bar there are to many chances to make a mistake so set a routine and don't wavier from it or you'll make a mistake !! I can bore with that ol' girl and hit my target diameter within .00025" yes a 1/4 thou , final pass has 2 air nozzles @ 60 psi blowing down the bore to keep the cutting tool cool and the bore cool
You should use one or two of those air nozzles that basically separates the hot air from the cool air. Called a Cold Air gun. I use them for surface grinding. They aren't very expensive either.
BigDave65- Posts : 567
Think i would get some Certanium 889 sp rods and reconnect the cylinders to the block on bottom. They are totally awwesome rods and dont warp anything and wels anything together just about. Better then furnace brazing.
ED468- Posts : 200
I need to be able to change the sleeves out without pushing the bores around them out of round . this is the reason for this work , sometimes when you have your toes hung over the edge you miss the tune by 1/2 degree of timing and have to change a piston or 2 , this makes it relatively easy to change a piston and sleeve in a couple of hours rather than have to remachine the whole block because of an oops!ED468 wrote:Think i would get some Certanium 889 sp rods and reconnect the cylinders to the block on bottom. They are totally awwesome rods and dont warp anything and wels anything together just about. Better then furnace brazing.
The last block I did this to lasted 21 years (1403 passes )until we had a really bad OOPS!
when you have a piston the vanishes off the end of a connecting rod @ 9000 rpm this is what you find ! rod was still intact with the pin in it ! .180 wall Tool Steel pins are Strong!!
Damn I show my secrets on making big power and only 33 relies but 600 views !!!! lol
everyone just taking Notes !! lol
That's one of those special blocks that have the "self expanding" bores!!Frank Merkl wrote:when you have a piston the vanishes off the end of a connecting rod @ 9000 rpm this is what you find ! rod was still intact with the pin in it ! .180 wall Tool Steel pins are Strong!!
BBFTorino- Posts : 999
Very nice work Frank!!
I learned a long time ago about doing it yourself as well!!
Its always nice to save a block and make it better. If you put this much into the bores, I'm sure there is a trick or two in other areas of the block lol!!
Bill
Bill
billandlori- Posts : 2081
Frank Merkl wrote:Damn I show my secrets on making big power and only 33 relies but 600 views !!!! lol
I'm definitely taking notes. I just got an A460 block and rotating assembly from Lem. I already had the SCJ heads and Mafia intake, so I'm getting close to making some noise.
cletus66- Posts : 865
Today was pre assembly day , as were putting a . 100" shorter rod in the motor 6.700 vs 6.600 . with pistons withe .100 " thou less valve relief trying to get the ring package away from the top ring land which is the first burn through on a nitrous motor . well the pistons are 25 grams heavier and the shorter rods weigh 6 grams heavier ! 4.5 hrs latter were within 1/2 gram of are 2200 gram bobweight which is a 51% over balance . all 8 pistons clear the counter weights Now , small ends of rods clear the counter weight at the pin end Now ! Assemble the motor with out rings . degree the New Montie Smith NOS cam , install heads with checker springs on 2 holes, Check piston to valve clearance , port match heads to intake , take it all back apart , file fit the rings . assemble the heads for final assembly . then clean, clean and re clean everything !! that's what I did in 19 hours on my sunday!!! Time for a Rum !!! Tomorrow final assembly !! Hell I forgot eat today !!! Calories In Rum? LOL
Tomorrows another day ! turned 60 this year !And the Doc told me I don't have 10 left !!So I better go Hard while I can ! MS is a Bitch!!!
oops ! old rod was a 6.800 rod!
Just another day in the life of Frank.
Looking awesome, and I have to agree now that if anything needs to be done the way you want it, it's best to do it yourself.
kjett- Posts : 1169
How deep are the cylinders when finished Frank? 6.25" long?
Does the piston pin come out below the bottom of the cylinder with the 6.7" rods?
Cheers
Cheers
68galaxie- Posts : 351
the finished sleeves in the block are 6.35 " long now as the bottom register on the one side sits over the main so I made the sleeves longer than the original cylinder wall
Frank Merkl wrote:oops ! old rod was a 6.800 rod!
So, the new rod is 6.7" ?
Frank Merkl wrote:Today was pre assembly day , as were putting a . 100" shorter rod in the motor 6.700 vs 6.600 . with pistons withe .100 " thou less valve relief trying to get the ring package away from the top ring land which is the first burn through on a nitrous motor . well the pistons are 25 grams heavier and the shorter rods weigh 6 grams heavier ! 4.5 hrs latter were within 1/2 gram of are 2200 gram bobweight which is a 51% over balance . all 8 pistons clear the counter weights Now , small ends of rods clear the counter weight at the pin end Now ! Assemble the motor with out rings . degree the New Montie Smith NOS cam , install heads with checker springs on 2 holes, Check piston to valve clearance , port match heads to intake , take it all back apart , file fit the rings . assemble the heads for final assembly . then clean, clean and re clean everything !! that's what I did in 19 hours on my sunday!!! Time for a Rum !!! Tomorrow final assembly !! Hell I forgot eat today !!! Calories In Rum? LOL
That's the win/win deal about a big shot of NOS engine.....if a guy makes the piston to head wider the intake valve relief can get a lot shallower.
Lem ! new rods are 6.700 Venolia's
Progress today
and the Beast of an intake we'll be spraying 3000 pph
Progress today
and in my spare time today I sealed and reclutched the C6 so it's ready to go to war !
and freshioned my peterson dry sump pump as it eat alot when the motor self de-assemble threw the lights at 9600rpm last year after it was shut off !!
forgot to paste! LOL
but the Captain Morgan spiced rum is tasting GOOD Now !!
I never drink while working but when the Day is done ! I love a drink or 6!!!!
Frank, what is the in-line valve looking thing in the C6 cooler lines for?
DILLIGASDAVE- Posts : 2262
» Cometic MLS head gaskets
» distributer block hole is too small on an A460 block
» Differences between stock type block and the a460 block?
» wanted a460 block or eliminator block.
» A460 block....
» A460 block....
Page 2 of 5
