Cam master -lobe measurements?
I bought a long block in a trade with some iron CJ's and a solid roller setup. It is an Ultradyne with .739" lift, but I have conflicting information between the previous owner (who had the box but not the cam card) and when I call Bullet / Ultradyne.
Is there someone that I can send the cam to that can measure the lobe profiles? I'm afraid this thing may be too long in duration to run in a street / strip project.
fox331- Posts : 28
Re: Cam master -lobe measurements?
That's a pretty time consuming job to set that up in a block and do a complete "bell curve" of the timing points unless someone has a cam doctor to measure it outside a block.
I know that Bullit & Comp & Crower & Isky & Lunati & Camotion have their own cam doctors for just this purpose.
I had my 428cj cam measured by cam doctor. I sent it to Scott Johnston, he may be able to help you.
Here's his contact info:
http://reincarnation-automotive.com/
nickbay- Posts : 61
http://reincarnation-automotive.com/[/quote[/url]]nickbay wrote:I had my 428cj cam measured by cam doctor. I sent it to Scott Johnston, he may be able to help you.
[url=http://reincarnation-automotive.com/
X2 on that... Scotty can fix ya right up...
Doug...
ThndrChkn- Posts : 2216
» Big lobe & lower ratio rocker or smaller lobe & high ratio rocker? whcih will live and which makes more power?
» wont idle / help please
» Lobe seperation - Manual vs Automatic
» 562 possible cam swap
» lobe seperation angle
