Cat Main Caps
crittersf1
Tore
Cat Main Caps
Can you still buy those Chinese Main Caps from Cat? I never see them listed anymore.
Tore
Tore
Tore- Posts : 865
Re: Cat Main Caps
crittersf1 wrote:I think CAT has gone by the wayside
Just found them during lunch. They go Speedmaster. There harder than wood pecker lips to machine but if you take and reduce your depth of cut your ok.
Tore
Tore- Posts : 865
Re: Cat Main Caps
Tore wrote:crittersf1 wrote:I think CAT has gone by the wayside
Tore
The milodon caps are much nicer
Re: Cat Main Caps
How hard is a woodpeckers lips?Not as hard as getting eggs and water at Norw@lk on a sat. morn.Tore wrote:crittersf1 wrote:I think CAT has gone by the wayside
Tore
Re: Cat Main Caps
I saw a set of caps at PRI several years ago but can't remember who was making them
crittersf1- Posts : 521
Re: Cat Main Caps
bbf-falcon wrote:How hard is a woodpeckers lips?Not as hard as getting eggs and water at Norw@lk on a sat. morn.Tore wrote:crittersf1 wrote:I think CAT has gone by the wayside
Tore
About even I figure!
Tore- Posts : 865
Re: Cat Main Caps
The place that sells them are out of stock but for $100.00 for a set I can't buy the material and make them my self.crittersf1 wrote:I saw a set of caps at PRI several years ago but can't remember who was making them
I have a set in an engine now and have had no issues at all. As I say they do spark a little when your cutting them if the depth of cut is to heavy.
Tore
Tore- Posts : 865
Re: Cat Main Caps
Tore
The 385 Series main caps that have been supplied by CAT and Procomp are not identical between the two suppliers.
We've regularly had to take very light passes with the CAT caps due to their hardness; a lot of patience is required to machine past the case hardening but after that they are not unusual.
We have never had this problem with the ProComp (Speedmaster) main caps; they always machine easily, as expected, and without issue. Unfortunately they have been on back order for quite awhile now and it's anyone's guess when they'll be stocked again.
Re: Cat Main Caps
"Pro-Gram Engineering" makes the best alloy steel main caps I have ever seen ... and, they are right in Barberton, Ohio.
Re: Cat Main Caps
Tore
As hard as calculus.
maverick- BBF CONTRIBUTOR
Re: Cat Main Caps
Just had a set put "adapted" to a D1. Nice stuff!rmcomprandy wrote:"Pro-Gram Engineering" makes the best alloy steel main caps I have ever seen ... and, they are right in Barberton, Ohio.
J.Toney- Posts : 398
» FORGED 557 ROTATING ASSEMBLY, TFS A460 HEADS, BILLET 4 BOLT MAIN CAPS, ARP MAIN STUDS
» Wanted: splayed main caps
» 4 Bolt caps
» Main caps..
» WTB OEM 460 Main Caps
» 4 Bolt caps
» Main caps..
