Rocker arm preference ?
5pointslow
Any preference on brand
600 to 650hp
Eddy head
Need 7/16 stud 1.73 ratio
I'm sure most will work in my application not looking to go crazy on somthing not needed
I see Harland sharps, tfs,scorpians ect...
Just wasn't sure if I should stay away from anyone certain
600 to 650hp
Eddy head
5pointslow- Posts : 1408
Re: Rocker arm preference ?
Harland Sharp is the only stud rocker I have been happy with in the last 25 years.
Curt- Posts : 2791
Spendy, but if you can go with the Crower Stainless, you'll never have to buy another set.
5pointslow wrote:Any preference on brand
600 to 650hp
Eddy head
Spring loads?
162 lb at installed height
384 lb at.500
Lunatic pn74708
384 lb at.500
Lunatic pn74708
just ordered harland sharp part # S4005
hope these work out fine for me
thanks
thanks
5pointslow wrote:just ordered harland sharp part # S4005
thanks
Those rockers on your Eddy heads will require a shorter pushrod and the wipe pattern on the valve will be toward the outside of the valve.
The S4073 is a better fitting rocker arm however, the less expensive S4005 will work.
This!!...Crower stuff is among the very best you can buy!!David Cole wrote:Spendy, but if you can go with the Crower Stainless, you'll never have to buy another set.
BBFTorino- Posts : 999
rmcomprandy wrote:5pointslow wrote:just ordered harland sharp part # S4005
thanks
Thanks for that tip good to know when im measuring push rods and wondering why im needing shorter ones , yeah i didnt really wanna spend the 400$ plus on the rockers .....just figuared these maybe a good one for the money . Seems most on here and some of the builds i see people use the harland sharps
» Acceptable roller rocker contact at valve tip and pushrod to rocker contact?
» Big lobe & lower ratio rocker or smaller lobe & high ratio rocker? whcih will live and which makes more power?
» Rocker arm?
» WTB rocker arms
» Rocker arm roller
» Rocker arm?
» WTB rocker arms
» Rocker arm roller
