Going 1.58 gear
+6
noslo533
dr's wife racing
chuck
10 posters
Going 1.58 gear Empty Going 1.58 gear
Post  chuck July 20th 2016, 10:50 pm
Getting a 1.58 installed next week. Looking for some opinions on rear gear, stock susp 1/8 mile racing.
chuck
Going 1.58 gear Empty Re: Going 1.58 gear
Post  richter69 July 21st 2016, 9:11 am
What tire and rear gear now?
Post  chuck July 21st 2016, 8:48 pm
richter69 wrote:What tire and rear gear now?
28x10.5 3.89 gears.I talk to K Szabo he said the 3.89 would be close.
chuck
Post  dr's wife racing July 22nd 2016, 8:59 am
Depends on your power and NOS use. I have a 3.55 in mine right now
dr's wife racing
dr's wife racing
Post  rmcomprandy July 22nd 2016, 10:17 am
chuck wrote:Getting a 1.58 installed next week. Looking for some opinions on rear gear, stock susp 1/8 mile racing.
Get the multiplied starting line gear ratio right and the rest will fall into place.
What ratio did you have before and how did the vehicle leave...?
Post  chuck July 22nd 2016, 11:52 am
dr's wife racing wrote:Depends on your power and NOS use. I have a 3.55 in mine right now
What your best 60ft?
chuck
Post  chuck July 22nd 2016, 11:54 am
1.80 with 3.89 rear. Best 60 so far was1.19. We make 1050hp on motor, and 400 with a plate system.
chuck
Post  whatbumper July 22nd 2016, 12:06 pm
Make high gear happy.  I'd go with a 4.10 with slick. We run 4.30 with radial but we dont need the wheel speed the slick needs.
Your setup sounds close to our limited cars and we 60' 1.08-1.12 on radial with that formula.
Post  noslo533 July 22nd 2016, 1:44 pm
heres my combo.. 3100lb bbf makes around 900 on motor 350 hit 3.70 rear gear 4800 stall, 6000 on nos. best 60 .13 will go consistent 1.16 low 4.90s leaving at 40% for .5 with a fogger.. I tried 4.10 became a wheelie wagon, moved bars blew tires off, changed again wheelied down track. felt faster but never eted like the 3.70s, changed back right back to where we were.. goes thru at 6600 going 146 goijng to up the tune when the weather cools off. don't like racing in the heat...Good Luck
noslo533
Post  rmcomprandy July 22nd 2016, 1:56 pm
Judging by what you had...
a 4.10 to 4.30 would be about right.
Post  whatbumper July 22nd 2016, 2:29 pm
noslo533 wrote:heres my combo.. 3100lb bbf makes around 900 on motor 350 hit 3.70 rear gear 4800 stall, 6000 on nos. best 60 .13 will go consistent 1.16 low  4.90s leaving at 40% for .5 with a fogger.. I tried 4.10 became a wheelie wagon, moved bars blew tires off, changed again wheelied down track. felt faster but never eted like the 3.70s, changed back right back to where we were.. goes thru at 6600 going 146 goijng to up the tune when the weather cools off. don't like racing in the heat...Good Luck
If you are really running 146 you have enough mph to be running high 70's.
Post  noslo533 July 22nd 2016, 2:37 pm
Your right I'm lying never done anything... I'm out.. SMDH
noslo533
Post  whatbumper July 22nd 2016, 4:33 pm
Not saying you're lying, don't get your undies in a wad.  Saying that you have a lot left in your front half and might want to fiddle with your setup.  With that MPH on that tire you should front half between a 3.10 and 3.13 if you're not then you're leaving a lot of et on the table.
Post  DILLIGASDAVE July 23rd 2016, 3:35 am
whatbumper wrote:...........Not saying you're lying, don't get your undies in a wad.........
Heh, damn internet misunderstandings.
Post  Lem Evans July 23rd 2016, 9:47 am
On March 9, 2016 noslo533 sent me a text. It is a picture of one of his time slips. It reads:
1.201
3.271
4.960
145.59
He said it was a 44/28 tune...whatever that is....and said the 60' was soft due to the run being during a street car tnt session.
Post  richter69 July 23rd 2016, 11:05 am
No doubt
Post  cool40 July 23rd 2016, 1:23 pm
Lem Evans wrote:On March 9, 2016 noslo533 sent me a text. It is a picture of one of his time slips. It reads:
1.201
3.271
4.960
145.59
it would appear like whatbumper could be correct. study
Post  Lem Evans July 23rd 2016, 2:13 pm
1.201
3.271
4.960
145.59
I never said he was wrong Smile
Per this post from March it seems noslo knows that there is et to be had from better short times.
https://www.429-460.com/t24256-finally-4s
Post  dr's wife racing July 23rd 2016, 3:29 pm
Sorry lost track of post. Low 1.20 to mid teens. Mine is not fully sorted yet.
dr's wife racing
dr's wife racing
Post  NoSlo5.0 July 23rd 2016, 4:31 pm
Lem Evans wrote:
1.201
3.271
4.960
145.59
Its been quicker and faster with a lesser tune after I changed converters..but motor is coming out and we wont be able to see where it could go.. this wasn't a max effort type deal. Never hurt anything, except a plug strap once.. the guys I know running ultra are going to less gear and going quicker as they fine more power.. those guys run sb's.. With lems Help I'm building a max effort motor and were gonna see how fast she can now...
NoSlo5.0
Post  chuck July 25th 2016, 10:10 pm
I'll have some feed back in a couple weeks.
chuck
Post  whatbumper July 26th 2016, 1:10 am
Looking forward to hearing your results.  I'm really fond of that planet as we sell more than our fair share of them. We attempt to keep four on the shelf but that is not easy these days.
