rebuild kit review please
going with a tci wide ratio planatery set and this is my other parts list I feel like im missing something please take a look and let me know
Thank,
Steve first time for ordering by pieces
A26744UP6
FRICTION MODULE REVERSE (72 teeth .075") 6 PLATES C6 / E4OD ALTO RED EAGLE
ALTO C6, E4OD, 4R100 FORWARD POWERPACK 6 FRICTION HI-PERFORMANCE RED FRICTIONS and KOLENE STEELS. INCLUDES PRESSURE PLATE AND APPPLY PLATE
A26757HP
POWERPACK, ALTO C6, E4OD, 4R100 DIRECT POWERPACK 6 FRICTION HI-PERFORMANCE RED FRICTIONS and KOLENE STEELS. INCLUDES PRESSURE PLATE.
N36022C
BAND INTERMEDIATE ALTO HIGH PERFORMANCE POWERBAND RED RACING
ROLLER - LOW CLUTCH - 16 ROLLER (C6 all years) (E4OD 89-4/97
A36974A
PISTON RETURN SPRING DIAPHRAM FORWARD CLUTCH .076" THICK C6 66-E76
26703KUP6
STEEL PLATE, REVERSE KOLENE STEEL MODULE (6 PLATES) C6 / E4OD / 4R100 / 5R110W
U36146
PRESSURE PLATE (GOOD USED) (.337") FORWARD / DIRECT FLAT C6 / E4OD / 4R100:
36175T
SEALING RING KIT C-6 66-96
TEFLON RINGS
36238A
BEARING, (C6, E4OD, 4R100: FORWARD CLUTCH DRUM to PLANET) and (FRONT PLANET to SUN GEAR; E4OD, 4R100 ) (AOD, AODE, 4R70W HUB to FORWARD DRUM 82-UP)
36321
GASKET VALVE BODY C6 67-UP
36002CF
OVERHAUL KIT WITH DURAPRENE (FIBER PAN GASKET) C6 L67-UP
Thank,
A26744UP6
A26757HP
N36022C
A36974A
26703KUP6
U36146
36175T
TEFLON RINGS
36238A
36321
36002CF
70429scj- Posts : 348
» WTB Pistons\crank
» E85 Mark Sullens Review
» rebuilding a C6
» Can somebody review my engine specs?
» 87 - ZF 5 Speed & 460 into 75 Highboy? Anyone???
» rebuilding a C6
