Dizzy gear clearances
Dizzy gear clearances Empty Dizzy gear clearances
Post  bbcoupe September 16th 2016, 9:31 pm
I've got a clearance issue with the Dizzy Gear and cam gear.
It's a lot tighter when installed in a SVO A460 block as compared to the old D0VE block.
Pic is of same cam, dizzy and gear fitted in both blocks.
Dizzy gear clearances Dizzy%20gear%20comparison_zpswnkbjzdu
bbcoupe
https://www.youtube.com/user/coupe545
Dizzy gear clearances Empty Re: Dizzy gear clearances
Post  Gregaust September 17th 2016, 3:39 am
Best idea i think would be to blue the gears and see what the contact patch is like , just like setting up diff gears
Gregaust
Post  bbcoupe September 17th 2016, 4:00 am
Gregaust wrote:Best idea i think would be to blue the gears and see what the contact patch is like , just like setting up diff gears
It's binding up deep in the groove, there are wear marks from a short run in the A460 block before teardown. No contact when in the old block.
Dizzy gear clearances 55e41147-fabb-4e54-880e-f62851ab0348_zpsths0hxrj
bbcoupe
Post  Gregaust September 18th 2016, 3:05 am
Very interesting. An unusual problem , hopefully someone has seen this before .
Gregaust
