Any run one of these with a tunnel ram and waht's it like?
PART 351511 ENGINE TYPE: MECHANICAL SPECIAL
GRINDN F-266/3528-2-8
ENGINE 1968-UP FORD-MERCURY V-8 370-429-460 CU.IN.
MODERATE COMPETITION ONLY, GOOD MID &
UPPER R.P.M. H.P.
VALVE SETTING: .026 EXHAUST .026 HOT
INTAKE @ CAM
3528 @
603 ROCKER ARM
INTAKE @ CAM
3648 @
624 1.71 ROCKER ARM
LIFT: EXHAUST @ @
ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER RATIOS
CAM TIMING
OPENS
CLOSES
ADVERTISED
.020 EXHAUST INTAKE 47 BTDC 75 ABDC 302 ° °
TAPPET LIFT EXHAUST
88 BBDC 44 ATDC 312 °
SPRING
RECOMMENDED RPM
RANGE WITH
TRIPLE DUAL OUTER MATCHING
PART
99890 MINIMUM RPM 4400
LOAD CLOSE
131 LBS @ 1.900 O 1 29/32 MAXIMUM RPM 7800
OPEN:
370 LBS @ 1.330 VALVE FLOAT 8400
CAM TIMING
OPENS
CLOSES
MAX LIFT
DURATIO
@ .050 INTAKE
30 BTDC 56 ABDC 103 ° ATDC 266 °
TAPPET LIFT EXHAUST
71 BBDC 25 ATDC 113 ° BTDC 276
UPPER R.P.M. H.P.
INTAKE @ CAM
3528 @
603 ROCKER ARM
INTAKE @ CAM
3648 @
624 1.71 ROCKER ARM
LIFT: EXHAUST @ @
CAM TIMING
OPENS
CLOSES
ADVERTISED
TAPPET LIFT EXHAUST
SPRING
RECOMMENDED RPM
RANGE WITH
PART
LOAD CLOSE
OPEN:
CAM TIMING
OPENS
CLOSES
MAX LIFT
DURATIO
@ .050 INTAKE
TAPPET LIFT EXHAUST
fozwanger- Posts : 25
Re: Any run one of these with a tunnel ram and waht's it like?
with what heads? auto,stick? stall rpm?
BOSS 429- Posts : 2372
Ported Dove C's, TH400, 3000 stall, 2000 lbs car
Foz, hope you've seen this. I did tellya.
https://www.429-460.com/transmission-tech-f7/th400-question-t2549.htm?sid=3829217421975ae819d433fc98ab0419
Paul-uk- Posts : 28
I'll have a read
Paul-uk wrote:Foz, hope you've seen this. I did tellya.
I have a C6 also, rebuilt with manual reverse pattern shift kit for good measure
» Old Style Trick Tunnel Ram Vs. New Style Trick Flow R Tunnel Ram
» Tunnel Rams for the Street??
» Modified Tunnel ram
» 351 w hi ram / tunnel ram
» Looking for TFS Tunnel Ram with dual dommi top
