Suggestions or options to go faster
+10
Straubtech
Carl
away
14 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Suggestions or options to go faster
And the title of the thread was? /\
You asked how to go faster
BOSS 429- Posts : 2372
68galaxie wrote:Adrian,
The engine seems to make very decent power 750+ with that tiny camshaft.
I do like Lem's suggestion of a little larger camshaft.
Don't be insulted by R Malik - He gets this way all too often. Maybe a bad day at work? Who knows.
Buy a custom cam from him. Just kidding. I think we need a bit of humor here sometimes.
Cheers
Ha Ha I know you are right. I was actually laughing the entire time I was writing back my twisted sarcastic response lol. Yes and I do know Lem from my Windy Hollow dazzzz and trust what he says about waking that thing up lol.
Now for you guys that know piston to valve clearances (and I know nothing is validated until checked and I do have checker springs for the heads once I get a new cam)
How do you think the clearances will change if I go with the cam numbers or there abouts that Lem suggested?
Going from the 296BR-8 to the bigger bumpstick. 260*/268* on a 108 to Lems suggested 272*/280* on a 110*
away- Posts : 266
away wrote:68galaxie wrote:Adrian,
Cheers
Do the pistons have an exhaust valve relief?
Cheers
I think ... NO ... I know you have absolutely no idea about me or actual experience of what you are talking about here but, you just have that need to insert your 2 cents anyway.
You are nothing here but a troll as no positive knowledge actually pertaining to the subject ever comes from whatever you write.
YES ... it was facetious; mainly because he DID convey that he has never had to change his dial-in for all 7 runs throughout the day with alcohol versus gasoline. Unless the weather and temperature did not change at all, that was probably BULLSHIT, (or grossly stretching the truth), running alcohol OR gasoline; just not as much with alcohol.
However, it was never said for him to run gasoline but, to "put a carb on it".
I am pretty sure that "away" understood the razz but, if he didn't ... oh, well. That is how it was meant.
I think we all know who the troll is here. I did offer the OP some advise in his post
You chose not to. - and just called him out as a Bullshitter.
My comment towards you - the usual grump was humor - grow a pair.
68galaxie- Posts : 351
Lem Evans wrote:away wrote:68galaxie wrote:Adrian,
Cheers
The pistons have one valve relief....probe pistons I think that is the intake valve correct
away- Posts : 266
away- Posts : 266
Lem Evans wrote:Yes, that's the intake relief.
So why did you ask? Because of my piston to valve clearance question? Would this stop the cam change that you suggested?
away- Posts : 266
Is that piston a .080 over or .030 over?
Darrin Gorham- Posts : 180
away wrote:Lem Evans wrote:Yes, that's the intake relief.
^^^Yes ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ It'd probley work......it will limit how much cam you can run at some point. Just put a small exh. relief if needed.
gt350hr is a piston guy....maybe he'll jump in here. How much have the heads been milled?
Darrin Gorham wrote:Is that piston a .080 over or .030 over?
The actual pic is from my spare 521 combo so it is .030 over but the same brand (probe) pistons are in the 532 (engine per this discussion) at .080 over.
Good catch apparently you know your stuff!
away- Posts : 266
Lem Evans wrote:away wrote:Lem Evans wrote:Yes, that's the intake relief.
I did buy the heads used and them sent them to high velocity heads in knoxville and they did surface them while they were there so I can not say for sure how much has been taken off of them.
away- Posts : 266
If you can figure out the free drop on the exhaust valve It'd go a long way toward what needs you may or may not have relative to an exh. valve relief.
Well I have figured out the plan as to how to go faster. I just had a set of bare (installed guides and seats only) c460 heads and intake arrive to my door!
Time to start another build thread lol. Who has an A460 block?
Adrian
Adrian
away- Posts : 266
away wrote:Well I have figured out the plan as to how to go faster. I just had a set of bare (installed guides and seats only) c460 heads and intake arrive to my door!
Adrian
I can have one to you in two days.
» Rocker Arm Options- Suggestions
» Another gas vs alky test..................
» What do I need to do to get this thing to run 10.0's? Sorry long post.
» DOG vs GUN! what's FASTER?
» Getting faster
» Getting faster
Page 3 of 3
