QUICK FUEL CARB ?
+16
QtrWarrior
605FOX
ThndrChkn
kjett
Northwest outlaw
Barney
20 posters
QUICK FUEL CARB ? - Page 2 Empty Re: QUICK FUEL CARB ?
Post  bruno December 11th 2009, 10:20 am
jbozzelle wrote:Does it wipe clean or does it wipe off and leave the anodized aluminum with pits?
Looks like plain old corrosion to me... But then again I am on the coast and have never had a carb look like that. But my small block did have the gritty exhaust ports from running VP C-12.
so i took some wd-40 and clean one up and there is a slight pitting in the machined marks ..........
http://WWW.CKRME.COM
Post  Barney December 11th 2009, 10:28 am
I stored my car in the trailer over the winter one year and checked on it from time to time and as it got colder frost developed on my valve covers and headers when the frost went away it left deposits like that. I just polished it off with mothers, but there was some permanent pitting. Im assuming that since your so far south frost is rarely an issue, but condensation would likely oxidize the same. I always put my carb in a sealed box and put it on the shelf in the winter so come spring time there isnt any drama.
Barney
Barney
Post  bruno December 11th 2009, 10:35 am
i just wonder why my prosystems carb never did that ???
Post  richter69 December 11th 2009, 10:42 am
Its got to be moisture from condensation, seems the last outing you were in some cool air.
WD40 fog after race.
For the winter I like to pull my carb off, clean it out with some brakeclean and WD40 the snot out of it, seal in a bag, put it in a box.
Post  ThndrChkn December 11th 2009, 11:08 am
I agree with Jon Nick, I'd be for pullin the bowls off, maybe even pull the carb apart and give it a good cleaning... It does look like it's been there awhile, I'd bet it was caused from the high humidity and salty air from Florida...
X2 on pullin' the carb off during the off season for a hose down and WD-40 fog...
Doug... QUICK FUEL CARB ? - Page 2 Icon_cool
ThndrChkn
ThndrChkn
Post  Lem Evans December 11th 2009, 9:00 pm
bruno wrote:i just wonder why my prosystems carb never did that ???
The carb did not do 'it' . Something in the air or fuel .
Post  Nevs December 11th 2009, 9:13 pm
X2, the brand of carb has nothing to do with "it"!
Post  bbf-falcon December 12th 2009, 5:50 am
Thats some Nasty lookin shit Nick, better get that thing cleaned up Quick. If its in the fuel,your regulator, Alum lines, and Fuel pump need to be checked also. Crying or Very sad
Post  605FOX December 12th 2009, 8:50 am
that carb is garbage .............. i will take it off your hands Very Happy ....... j/k if the bowls look good then it is not fuel has to be some kind of condensation ....... if my memory serves me right werent you the one that had the pissing edelbrock head ............ i would run a pressure test and see if that head is pissing liquids again .....maybe just steaming after a run .......... thats just too much normal condensation
just my .02 Very Happy
605FOX
Post  res0rli9 December 13th 2009, 1:25 am
605FOX wrote:that carb is garbage .............. i will take it off your hands Very Happy ....... j/k if the bowls look good then it is not fuel has to be some kind of condensation ....... if my memory serves me right werent you the one that had the pissing edelbrock head ............ i would run a pressure test and see if that head is pissing liquids again .....maybe just steaming after a run .......... thats just too much normal condensation
forgot bout the pissy head, x2 on checking it
Post  dfree383 December 13th 2009, 7:34 pm
I'm thinking its the chemicals in the "hot" fuel you've been running, stuffs pretty nasty.....
Post  richter69 December 13th 2009, 7:40 pm
was it monster 114 or monster ox 114?
Post  bruno December 13th 2009, 7:44 pm
richter69 wrote:was it monster 114 or monster ox 114?
couldnt tell you jon ........
Post  Lem Evans December 13th 2009, 7:45 pm
dfree383 wrote:I'm thinking its the chemicals in the "hot" fuel you've been running, stuffs pretty nasty.....
pretty or nasty ? Laughing
Question is.......what does the top of the butterflies look like ? If/when they are relatively cool looking....gotta think that it's something going on when the engine is not running .
Post  bruno December 13th 2009, 8:06 pm
the top of the bowls look like brand new Lem ........... im thinking that head is pissing some steam ??? ... i hope not ------ but there is no telling ......
Post  Lem Evans December 13th 2009, 8:08 pm
not the bowls...the butterflies.........
Post  QtrWarrior December 13th 2009, 8:08 pm
Finally had a chance to read this thread.
My QF carb had the same thing happen to it... But I run VP C-12.
I'm almost positive it's corrosion/ rust from condensation after the car has been run IN COOLER weather...
I say this, because I also found condensation in the valve covers when checking the valves..
Maybe...Just Maybe ???
QtrWarrior
QtrWarrior
Post  Lem Evans December 13th 2009, 8:13 pm
QtrWarrior wrote:Finally had a chance to read this thread.
I'm almost positive it corrosion/ rust from condensation after the car has been run IN COOLER weather...
A maybe + here .
Post  bruno December 13th 2009, 8:16 pm
Lem Evans wrote:not the bowls...the butterflies.........
the top side of the butterfly's look good also Lem
Post  Lem Evans December 13th 2009, 8:22 pm
Well....it's happening when the throttle is closed . When the engine is at W.O.T. the fuel is seeing both sides of the butterflies ...........case closed. santa
Post  QtrWarrior December 13th 2009, 8:26 pm
Motor warm, carb cool / cold ( especially when using phenolc carb spacer) car put into a cool/cold trailer on a cool / cold night. Yup..sounds like condensation to me..
QtrWarrior
QtrWarrior
Post  bruno December 13th 2009, 8:28 pm
here are some added pics ......... everything looks great in these pics
QUICK FUEL CARB ? - Page 2 005-11
QUICK FUEL CARB ? - Page 2 006-11
QUICK FUEL CARB ? - Page 2 007-11
QUICK FUEL CARB ? - Page 2 008-10
Post  Nevs December 13th 2009, 8:30 pm
The Godfather has spoken, heed his words... Idea
Post  richter69 December 13th 2009, 10:51 pm
yep, def condensation.....prolly mixing with the fuel residue and making a mess.
Alky guys are already fighting moisture from the get go, so after race procedures are already in place.
Fog with WD40, pull the plugs and breathers, prop the throttle open if need be.
Post  Oakley Motorsports December 15th 2009, 12:26 am
As a long time monster fuel dealer and a racer that has alot of experience with the Q16 I have never seen either fuel do that. I have seen carbs that have seen moisture or severe weather changes appear that way. Charlie if you are talking about the carbs that I used I never ran your metering blocks or float bowls. I just used the main body for testing. So any residue in the bowl would have been from something else. Nick if you need anything for your carb give me a call and I can help.
Oakley Motorsports
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
