Stud wear
Stud wear
My son-in-law just pulled the rockers and stud girdle on my P-51 headed motor. And we see some of the studs have wear in the area where the rockers go down over the studs. This is the first time I have ever seen this. Any ideas?
Tore
Tore
Tore- Posts : 865
Re: Stud wear
Is it worn down thru the metal, or just worn thru the black coating??
If you run your fingernail over the area and feel that it's into the metal, replace them!!
BBFTorino- Posts : 999
Re: Stud wear
Its worn thru the black oxide coating. There is a small amount of galling.
Tore- Posts : 865
Re: Stud wear
That's pretty normal. They will wear.Tore wrote:Its worn thru the black oxide coating. There is a small amount of galling.
Scott Foxwell- Posts : 419
» Valve tip wear
» cam gear wear
» What causes this wear pattern?
» Bearing Wear Question
» Distributor Gear Selection
» cam gear wear
