Deleting fuel pump concentric ring
Building a 429. I'm thinking of deleting the mechanical fuel pump ring that goes on the cam gear.
I am running a electric fuel pump to supply the Fitech FI carb.
Do i just remove the concentric and bolt the cam gear on? Any adverse effects from doing this?
Bob
Tucson
Bob
Tucson
75truck- Posts : 102
Re: Deleting fuel pump concentric ring
75truck wrote:Building a 429. I'm thinking of deleting the mechanical fuel pump ring that goes on the cam gear.
Bob
Tucson
Using a carb and switching to electric I usually left the FP concentric ring in place as a road side fix if need be, but with FI it likely won't help, so as far as I know the only adverse affects will be if the cam bolt bottoms out without the concentric spacer and torques the threads.
FalconEh- Posts : 1448
» Cam bolt - deleting the fuel pump concentric
» Do I need to remove my already intalled fuel pump eccentric if I'm now going to be using an electric fuel pump?
» Fuel Inj. Pump - Ron's Black Gear Pump - Size "0" - SOLD !!
» Spark plug fuel ring reading
» BG 400 fuel pump help
