Blue thunder dommy intake ?
I've got this 4 hole B/T dommy dual plane intake... bought it from a guy locally years ago thinking I could do something with it... how would a person build around this intake... cam, compression, heads, application any ideas? Street strip? I've heard dommy carbs are quite finicky for street use...
torino501- Posts : 417
Re: Blue thunder dommy intake ?
Will probably work best on something big, like 500+ inches.
BBFTorino- Posts : 999
Application= Bragging at the Car Show to the Lawn Chair Crowd. Sell it.
supervel45- Posts : 4498
It's for the CJ heads also... y'all prob already new that.
Yea I knew that. It's a cool intake and all but, I would not build an engine around it.
My thinking was that the 4 holes would make for a better vacuum signal to the carb for a little crisper throttle response over the open plenum with the middle divider that I see on the internet... the only 4 hole dual plane I've seen was a Shelby intake.
torino501 wrote:My thinking was that the 4 holes would make for a better vacuum signal to the carb for a little crisper throttle response over the open plenum with the middle divider that I see on the internet... the only 4 hole dual plane I've seen was a Shelby intake.
I guess my thought is that if you run a Dominator it is either for Race or Street Race use not low end or midrange torque. That would mean a single plane intake with a high stall converter or a manual transmission. Just seems counter productive. I also believe they make a BT with a regular divider and a Dommy flange.
https://www.google.com/search?q=blue+thunder+429+dominator+flange+intake&tbm=isch&imgil=q3-OnHRbri_-lM%253A%253B6c6dOOS5yHFZPM%253Bhttp%25253A%25252F%25252Fwww.460ford.com%25252Fforum%25252F41-auction-block%25252F145816-429-460-blue-thunder-scj-intake-dominator.html&source=iu&pf=m&fir=q3-OnHRbri_-lM%253A%252C6c6dOOS5yHFZPM%252C_&usg=__9WjZqBQ4sjgqD9ncmac5_efO9jM%3D&biw=1067&bih=529&ved=0ahUKEwiF2r-z0fbSAhWh6oMKHaa_DTwQyjcILg&ei=1f7YWMWbCaHVjwSm_7bgAw#imgrc=q3-OnHRbri_-lM:
This is the one I was thinking of.
They work very well on applications and classes requiring a dual plane, they are not "junk" by any means
supervel45 wrote:torino501 wrote:My thinking was that the 4 holes would make for a better vacuum signal to the carb for a little crisper throttle response over the open plenum with the middle divider that I see on the internet... the only 4 hole dual plane I've seen was a Shelby intake.
Not really a bigger carb is required with a dual plane and a Dominator with a dual plane could just be the right ticket for a bigger inch engine. It's all in the application.
It could help if you have limited hood clearance also.
The one I have is the 4 hole not the open plenum w divider wall... I don't see to many in the 4 hole configuration...
torino501 wrote:The one I have is the 4 hole not the open plenum w divider wall... I don't see to many in the 4 hole configuration...
Less volumn could work better depending on application
The 4 hole type will generally help increase the signal to each venturi, giving it a little better throttle response, but may not flow as much in the higher RPMs as the open plenum type.
» WTB Blue Thunder 429 CJ intake
» DISTRIBUTOR FOR BLUE THUNDER 2 PC. INTAKE
» Intake ?'s with Blue Thunder heads
» Blue Thunder tunnel ram intake
» Change of intake for my street car
