Valvetrain Geometry
Valvetrain Geometry Empty Valvetrain Geometry
Post  OldRedFord December 11th 2009, 4:46 am
What is proper valvetrain geometry? Having the rocker arm centered on
the valve stem through the range of motion? Push rod perpendicular to
the rocker arm?
I did look around on the net and found the below link helpful, but it talks about roller tipped rockers. Mine are the factory stamped rockers.
http://www.compcams.com/Technical/FAQ/ValvetrainGeometry.asp
OldRedFord
OldRedFord
Valvetrain Geometry Empty Re: Valvetrain Geometry
Post  rmcomprandy December 11th 2009, 12:01 pm
A factory type, non roller tipped rocker arm has completely different criteria than its roller tipped bretheren.
The rocker tip should sorta roll on the tip of the valve as it opens with as LITTLE scraping motion as possible. This usually means a tip pattern where the contact is on the very inside, (but not on the edge), and goes toward the outside of the valve stem tip using 75% of the area on the tip of the valve. A WIDE pattern however, centered on the valve tip.
A narrow tip pattern with a non roller rocker arm is a NO-NO because then there is an abundance of SLIDING motion happening there which will ultimately be bad for valve guide / valve stem wear along with excessive rocker tip wear...
Post  OldRedFord December 12th 2009, 12:08 am
Thanks for the info Randy.
OldRedFord
OldRedFord
