Help on oil pan for 429 engine!
Building a 429. I have a front sump stock pan with baffel and 2 indentations on the shallow end (or Rear) that are slightly hitting the rear of the windage tray when installed.
Can I use this pan and modify or bend the indentations out somewhat?
Or is there another solution?
I would prefer not to buy another pan.
Bob
Tucson
Bob
Tucson
75truck- Posts : 102
Re: Help on oil pan for 429 engine!
If you can cut and weld, you can make it fit.
BBFTorino- Posts : 997
Forgot to mention 75 Ford F250 ---
Forgot to mention going into a 75 Ford F250.
Bob
Tucson
Bob
Tucson
How much contact is "slightly"? Did you check the fit with a pan gasket in place?
If slight contact, take a hammer to the pan. Give it a couple of gentle raps - if it needs more than that, you'll need pan modifications or a different pan. IMO.
4604X4- Posts : 108
» 514ci BLUE THUNDER HEADED ENGINE & bbf parts,and engine for sale
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
» C9VE engine from 69 Continental -- Have questions about where to go with this engine
» ENGINE RPM DROPS & ENGINE DIES AT IDLE & BRAKE PROBLEMS
