429 Cobra jet heads
Roger Dyess
429 Cobra jet heads
Who can set these heads up for a 521 build for a Bracket car ?
Roger Dyess- Posts : 16
Re: 429 Cobra jet heads
Roger Dyess wrote:Who can set these heads up for a 521 build for a Bracket car ?
I'll recommend anyone on here who does cylinder heads for a living ... I would choose someone closest to your location.
Don't really need Max effort heads on a 521 bracket motor IMO.
429 Co fa Jet heads
Thanks for the advice and effort to do so. I have learned that improving any part of the drive train significantly , ripples through the combinationfront front to rear. It's my heads time to be improved. I have prepared the balance of the combination to handle a step up. I guess I have not done sufficient reasearch to know what horsepower upgrade I can get out of these heads while staying at 521. I'm a horsepower racer no boosters. Can't afford turbos of nitrous rebuilds. Thanks again. I will rethink the question
A-429 Aluminum CJ heads or cast iron i would think cast iron 429 Cobra Jets?
Mark Miller- Posts : 1959
Agree with Randy.
Also if you are talking about the factory iron CJ heads you will be far ahead using a custom designed camshaft.
Several here that can help greatly with that as well.
Cheers
Cheers
68galaxie- Posts : 351
i just took my A429 cjs off the 514 to be replaced with the p51s, motor is mild nothing too crazy, been 9.12 @148. 14:1 comp.
Rickytx630- Posts : 100
Rickytx630 if you need a new home for those a429 heads I've been on the hunt for a set
Lord_Vader- Posts : 3
Rickytx630 wrote:i just took my A429 cjs off the 514 to be replaced with the p51s, motor is mild nothing too crazy, been 9.12 @148. 14:1 comp.
what kind of car is it in?
BOSS 429- Posts : 2372
» Super Cobra Jet Heads
» old cobra jet heads to new scj"s ?
» Cobra Jet AR Heads
» 428 cobra jet heads
» Fox swap
» Fox swap
