valve springs for roller cam
Page 2 of 2
Page 2 of 2 • 1, 2
Re: valve springs for roller cam
Lem Evans wrote:If a guy wanted to get right down to it......the valves bounce and the springs float.
Is that what they call the hula-Hokie-Pokie??
dfree383 wrote:Lem Evans wrote:If a guy wanted to get right down to it......the valves bounce and the springs float.
-Hokie-Pokie?? [/quote] < happens a lot in the south ?
BOSS 429- Posts : 2372
I personally think a lot of people get pulled into the high spring pressure is a must and over spring.
I run a Manley Nextek 221424-16 250 @ 2.00 / 800 @ 1.150 647 spring rate.
2.300 stainless intake valve Ti retainers and .4375 x .165 wall pushrod.
7200 rpm shift point and has seen 8100 several times with zero sign of valve float.
6 years and checked several springs the other day and all were with in 15 lbs of original seat pressure of 165 lb.
On the O.P.'s engine combo, I would be around 220/600 with the 600 being .060 at max lift.
< happens a lot in the south ?[/quote]BOSS 429 wrote:dfree383 wrote:Lem Evans wrote:If a guy wanted to get right down to it......the valves bounce and the springs float.
-Hokie-Pokie??
I thought it was Okie-Pokie??
I have some Comp 999's for sale, not sure if they'll work for you.
68formalGT- Posts : 865
anything but Comp springs in my motors ...... I had good results with Howards pro alloy 98885 Dual with Damper 1.575od 245 @ 2.000 600 @ 1.300 485lb/in .740 max lift 1.200cb or Manley pro 22431-16 Chrome Silicon Double w/damper Oval / Drag 1.550" 225 @ 1.950" 507lb/in 580 @ 1.250" .725 max lift
1.190" Coil Bind... next up the ladder PAC-1289 1.550 1.136 No 0.812 230 @ 2.000 580 @ 1.300 500 1.210 0.750 .......If you want a top flight spring set Isky tool room 9375 plus or 9385 plus
Racerrick- Posts : 7
springs
thanks for all the replies.i have a set comp 943.they are 240 @ 1.950 and 580 @ 1.300 .they should work good.plan to keep this under 6400 rpm.net lift should be .633 with cold lash.
hbstang- Posts : 365
Page 2 of 2 • 1, 2
» Need help with valve springs
» Roller Springs F/S..........
» Valve Springs...
» Valve springs
» valve springs!
» Valve Springs...
» Valve springs
» valve springs!
Page 2 of 2
