Found this in the oil tonight..
+10
pmrphil
Gregaust
14 posters
So I drained the oil tonight and found 2 little springs on the drain plug magnet and I have no idea where/what they could be from. And after seeing them, I don't want to run the motor again until finding the source. Can any one offer a clue? Engine is a 514, solid roller cam, kaase pump, Milodon 7qt pan/pickup, roller rockers. standard cam bearings,
https://photos.app.goo.gl/sRFc5w4tkhdbzKRN2
https://photos.app.goo.gl/ugFoVy5XXPugIht92
any help appreciated.
Re: Found this in the oil tonight..
Is that off a couple Valve stem seals?
Mark Miller- Posts : 1959
looks like a spring from a crankshaft seal. That's interesting.
stanger68- Posts : 502
Yep, from the front seal.
BBFTorino- Posts : 999
stanger68 wrote:looks like a spring from a crankshaft seal. That's interesting.
I was thinking the same thing
Mike R- Posts : 1381
Yep front seal I was thinking too. No where else really
Gregaust- Posts : 626
Looks like the spring from the front crank seal to me to looks a little long for a valve seal. But you can pull the valve covers and check them 1st if none of them missing then pull the timing cover
Front seal is what we thought of, but I would have expected the spring to be longer or if broke in 2 pieces, I wouldn't expect the pieces to be the same length. Here is another picture, and from it, you can see the one spring is stretched a bit, and if not for that I believe the 2 springs would be the same length I think.
https://photos.app.goo.gl/2YYETDbC4ssqBPKv1
It would be easy enough to check if it's from two valve stem seals, otherwise it would have to be from the front crank seal. Nothing else internally that has springs like that!
Doug Rahn wrote:It would be easy enough to check if it's from two valve stem seals, otherwise it would have to be from the front crank seal. Nothing else internally that has springs like that!
Yep, going to pull the valve covers and check the valve stem seals. if that's not it, I'll be pulling the timing chain cover this weekend.
Definately a front crank seal spring - valve seals don't have that type of spring. If it's not leaking I wouldn't bother pulling it apart, the spring just puts tension on the sealing lip to prevent leaks.
pmrphil- Posts : 171
I went and looked at my timing chain cover front seal. The spring is towards the front of the cover and it is very hard to imagine it falling or breaking up and getting into the oil pan the way that it is made but, I guess anything can happen. Also seems like Ford could have made the seal changeable from the outside, oh well.
PS: It looks like you could inspect the spring pretty easily by just removing the balancer.
supervel45- Posts : 4499
the spring is supposed to be on the inside, NOT the outside, your seal is installed wrong, backwards
BOSS 429- Posts : 2372
Not leaking at this point.pmrphil wrote:Definately a front crank seal spring - valve seals don't have that type of spring. If it's not leaking I wouldn't bother pulling it apart, the spring just puts tension on the sealing lip to prevent leaks.
supervel45 wrote:I went and looked at my timing chain cover front seal. The spring is towards the front of the cover and it is very hard to imagine it falling or breaking up and getting into the oil pan the way that it is made but, I guess anything can happen. Also seems like Ford could have made the seal changeable from the outside, oh well.
BOSS 429 wrote:the spring is supposed to be on the inside, NOT the outside, your seal is installed wrong, backwards
On another site I read that the later model TC's had a seal that could be installed from the outside, (but yes the spring is to the inside). I don't remember if mine is like this, but if it is, can the seal be removed/installed without taking the cover off?
Next question is, if it is the crank seal spring, is there something else that could have caused the failure?
when the seal was installed it most likely popped out,and finally made its way to the pan. just was not caught,or it just broke,and fell in the pan
coin toss to know what happened
Not sure what's up with that seal. It's pressed in from the backside of the timing cover with the metal facing the inside of the engine.
supervel45 wrote:BOSS 429 wrote:the spring is supposed to be on the inside, NOT the outside, your seal is installed wrong, backwards
Ive seen it plenty of times, this one im guessing has a large flange on it,and its in backwards
Some install the seal backward. Say it holds vacuum better when done that way.
DanH- Posts : 1081
Then you have a later model seal put in an earlier model cover.
Early seals don't have a metal facing.
[quote="BOSS 429"]
Ive seen it plenty of times, this one im guessing has a large flange on it,and its in backwards[/quot
No it has the small/no metal lip flange like the old style. Yes it looks like it got in there backwards. Oddly the secondary lip does face the oil side and it did not leak.
As for the OP if he has the late model timing cover with the seal pressed on from the outside, he should be able to replace it by just removing the balancer.
» UFC Tonight 11/21/09
» Well, I went and done it tonight...........
» tnt tonight!
» Going to test tonight
» Proud Dad tonight. It gets better.
» tnt tonight!
