Priming oil pump on a short block
Priming oil pump on a short block Empty Priming oil pump on a short block
Post  75truck August 20th 2017, 10:30 pm
Just finished a 429 short block.
I thinking I could spin the oil pump and check the oil pressure, just insert the lifters and prime?
Would this work and if so what do I look for? Or do I need to install heads, pushrods and rockers and then prime?
Priming oil pump on a short block IMG_1470
Bob
Tucson
75truck
Priming oil pump on a short block Empty Re: Priming oil pump on a short block
Post  BOSS 429 August 20th 2017, 10:40 pm
TEST wont be real till you install heads,and all the valve train, and set the valves
