477 short block, pro comp heads, motor plate, and more
477 short block, pro comp heads, motor plate, and more Empty 477 short block, pro comp heads, motor plate, and more
Post  snoopstang January 5th 2011, 12:02 am
477 short block, Trw .060 L2443n pistons, h beam rods, stock crank, new rod bearings, new main bearings, new oil pump, roller timing chain, Lunati camshaft 61605 .582/600, 241/249@.050, 284/292 advertised duration. $900
Procomp heads ported, new never assembled, comp cams roller tip rockers, comp cams magnum push rods, studs, guide plates, PBM intake and exhaust valves 2.25, 1.9x intake new, exhaust used like new fresh ground, just add springs and retainers. $1050
# PC3005-460-0606-0497, push rods #7651
BBF Aluminum motor plate $75
All parts located in Poplar Bluff, MO Prices are plus shipping. email snoopstang@yahoo.com
477 short block, pro comp heads, motor plate, and more 687689939_photobucket_37435_
477 short block, pro comp heads, motor plate, and more 687689939_photobucket_37434_
477 short block, pro comp heads, motor plate, and more 687689939_photobucket_37443_
477 short block, pro comp heads, motor plate, and more 687689939_photobucket_37439_
477 short block, pro comp heads, motor plate, and more 687689939_photobucket_37440_
477 short block, pro comp heads, motor plate, and more 687689939_photobucket_37441_
477 short block, pro comp heads, motor plate, and more 687689939_photobucket_37444_
477 short block, pro comp heads, motor plate, and more 687689939_photobucket_37437_
snoopstang
477 short block, pro comp heads, motor plate, and more Empty Re: 477 short block, pro comp heads, motor plate, and more
Post  snoopstang January 13th 2011, 12:32 pm
added part #'s lets move this stuff...
snoopstang
477 short block, pro comp heads, motor plate, and more Empty short block
Post  bigunitmudracing January 14th 2011, 10:22 pm
how far in the hole are the pistons..??? balanced? where you located?
bigunitmudracing
bigunitmudracing
