Roller Cam
Roller Cam Empty Roller Cam
Post  Tennessee Bullitt December 13th 2009, 5:34 pm
Can someone give me a little better idea on how a solid roller setup would be as far as making my motor react different from a solid tappet? I know they say they are not good at low rpms, but as it sets I am looking at a 4,000 stall any way on my setup according to PTC with a flat tappet cam. I think I will opt to do a roller since my stall will be that big.
Tennessee Bullitt
Tennessee Bullitt
Roller Cam Empty Re: Roller Cam
Post  Lem Evans December 13th 2009, 5:52 pm
With a set of street SCJs I doubt a roller set up would make much more power but would add several $s more to the cost .
Post  Tennessee Bullitt December 13th 2009, 6:15 pm
I was looking at the throttle response and if any gains could be had. Thanks Lem.
Tennessee Bullitt
Tennessee Bullitt
Post  BOSS 429 December 13th 2009, 6:34 pm
Tennessee Bullitt wrote:I was looking at the throttle response and if any gains could be had. Thanks Lem.
leaving @ 4000 and above? thr res shouldnt be a problem, but a correct grind roller will make more power,and will be more responsive then a flat
Post  Lem Evans December 13th 2009, 7:03 pm
Given the flow curve of the SCJs...peak flow at or below .600" the roller just aint a big bang for the buck per your application .
Post  IDT-572 December 13th 2009, 7:07 pm
Lem Evans wrote:Given the flow curve of the SCJs...peak flow at or below .600" the roller just aint a big bang for the buck per your application .
x2 You beat me to it................. Cool
Post  Tennessee Bullitt December 13th 2009, 7:20 pm
so cleaning the lips up behind the valves don't increas the flow for higher lift, it just makes it more efficent?
Tennessee Bullitt
Tennessee Bullitt
Post  Lem Evans December 13th 2009, 7:38 pm
A good pocket port/bowl blend will pick up the flow on the intake side 40-45 cfm but it'd be unlikely that the peak point will move more than .025" . Will the flow pick up at .700"...yes but it'll still be about 20-25 cfm less than it flowed at about .600" .
Post  Tennessee Bullitt December 13th 2009, 7:58 pm
Thanks for correcting me Lem. I guess a solid it is then.
Tennessee Bullitt
Tennessee Bullitt
