Boss 9 OE oil drainbacks
Last edited by JBR-3 on September 20th 2020, 1:38 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Re: Boss 9 OE oil drainbacks
JBR-3 wrote:In the OE Boss blocks, do the oil drainback passages essentially run through the coolant area into the valley,
or down into the crankcase ?
Also, my understanding is that the flow capacity of the original drain-backs was marginal, is this correct ?
The OEM Boss 429 block oil drain-backs which I have seen are at a different location at the deck surface than a normal 385 series block. They go down to the crankcase in the rear and front cover area in the front.
I was told there are other versions of oil drain-backs in a Boss 429 block but, I have not seen what those might be.
Last edited by JBR-3 on September 20th 2020, 1:39 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
they can drain back a lot,there is no issue returning oil on a BOSS
BOSS 429- Posts : 2372
JBR-3- Posts : 266
» external oil drainbacks
» boss fords boss 429 scj /cj's boss 351
» BOSS
» Boss Hemi,SOLD !
» Boss 600 (598)
» BOSS
» Boss Hemi,SOLD !
» Boss 600 (598)
