external oil drainbacks
external oil drainbacks Empty external oil drainbacks
Post  STR-LGL-70 February 24th 2019, 10:04 pm
Anyone using external oil return lines with C heads? I know some of the boss heads use them just wondering if C heads need them or not.
Thanks, Sheldon G
STR-LGL-70
STR-LGL-70
external oil drainbacks Empty Re: external oil drainbacks
Post  Frank Merkl February 25th 2019, 12:23 am
not needed!
Post  STR-LGL-70 February 25th 2019, 7:31 am
Thanks Frank!
My new engine has them and is going to create a firewall clearance issue; been debating on whether to modify the firewall or remove the lines. I may still alter the firewall but at least I have options.
BTW the engine has billet fab alum pan with 4" kick out, Titan pump and Moroso 3 qt accumulator so it should be good.
Thanks again, Sheldon G.
STR-LGL-70
STR-LGL-70
