Sonic tester
Sonic tester Empty Sonic tester
Post  STR-LGL-70 December 2nd 2017, 8:49 am
I have a number of blocks I would like to test & it may make more sense to buy a tester & do it my self; then I'll have the tool for future use.
What price range do they run for something decent w/o getting crazy price wise? Any brand/model recommendations ?
Thanks, Sheldon
STR-LGL-70
STR-LGL-70
Sonic tester Empty Re: Sonic tester
Post  rmcomprandy December 2nd 2017, 11:28 am
STR-LGL-70 wrote:I have a number of blocks I would like to test & it may make more sense to buy a tester & do it my self; then I'll have the tool for future use.
Thanks, Sheldon
Right around $1,000.00 will get you a decent one.
There are cheaper Asian ones out there flooding the market giving inaccurate results; some are better than others.
Post  68galaxie December 2nd 2017, 12:26 pm
I was only testing a few blocks and didn't have the funds for a $1000.00 tester.
I decided to buy a cheaper version.
I bought a TM-8812 unit (Chinese made) - $150.00 I recall
I did have to machine the probe end with a radius - as it came with a flat surface.(most important thing I did)
However, when testing the unit it performed quite well. Accuracy not worse than 0.002"
This was certainly good enough for my testing.
I tested the unit on several areas of the block that I could measure with standard tools to make my
assessment.
68galaxie
68galaxie
Post  BBFTorino December 2nd 2017, 4:29 pm
Where do you buy them at??
Post  68galaxie December 2nd 2017, 4:56 pm
https://www.amazon.com/TM8812-Ultrasonic-Thickness-1-2-200mm-0-05-8inch/dp/B00DKW4IYO
68galaxie
68galaxie
Post  STR-LGL-70 December 6th 2017, 10:05 am
Thanks for the info; going to get one for work for checking glass thickness and I'll try it out on other things too.
Will let you know how it performs.
Thanks, Sheldon
STR-LGL-70
STR-LGL-70
