Dual bolt pattern flexplate?
I need a flexplate, 164 tooth, 28 oz for a sbf with dual bolt patterns. 11 7/16" and 10 1/2" for the converter. Needs to be a C-4/FMX. C-6 will not work due to depth offset.
I'm putting a late model 4R70W computer controlled transmission in my 69 Mach 1 with a 351C. Car currently has an FMX flexplate that will work but it only has the large bolt circle. I want the option of a smaller converter. Was going to do an AOD swap but the 4R is a much better and stronger transmission.
Re: Dual bolt pattern flexplate?
I never used one of these , but I think it maybe what you are looking for .
https://www.summitracing.com/parts/pma-pax30211/applications
whitefield- Posts : 2244
whitefield wrote:I never used one of these , but I think it maybe what you are looking for .
Thanks,
I checked the mfg website. It's got a dual pattern, but it says it won't work with the larger factory type converter (with lockup clutch). Their website says to use a different part # for the converter, but the one they advise only has a single bolt pattern.
Maybe Keith Fulp could drill some holes for you?
Bill Heard- Posts : 115
David - take a look at PRW #1830211 - should be the one you want.
Phil
Phil
pmrphil- Posts : 171
I think TCI has a part available
» Who makes a dual pattern piston?
» Question on dual pattern camshafts
» ZF bolt pattern?
» Need some advice on a pro street truck build
» I need the 460 oil pan bolt pattern
» ZF bolt pattern?
