Who makes a dual pattern piston?
Who makes a dual pattern piston? Empty Who makes a dual pattern piston?
Post  BBFTorino December 31st 2018, 1:38 am
Who can make pistons with valve reliefs for standard (stock / Edelbrock), and A460 style heads?? This is so I can get a motor together using Edelbrock heads at first, then just be able to swap on an A460 top end at a later date.
Who makes a dual pattern piston? Empty Re: Who makes a dual pattern piston?
Post  dfree383 December 31st 2018, 8:28 am
Any custom piston manufacture will make them for you, just be aware that you will see a large compression drop when going to the A460’s with a flat top. And I wouldn’t try doing it with a dome.
Post  rmcomprandy December 31st 2018, 12:37 pm
dfree383 wrote:Any custom piston manufacture will make them for you, just be aware that you will see a large compression drop when going to the A460’s with a flat top. And I wouldn’t try doing it with a dome.
Unless it is a big combustion chamber Edelbrock or D3 style combustion chamber head, originally.
Post  BBFTorino December 31st 2018, 11:48 pm
Thanks guys. The Edelbrocks are 73cc
