First 547 build
+8
duff429
12 posters
Page 2 of 2 Previous  1, 2
First 547 build - Page 2 Empty Re: First 547 build
Post  BBFTorino January 4th 2019, 3:00 am
Looking good. The Grabber Blue is an all time favorite color too!!
Post  duff429 February 9th 2019, 1:20 am
I still haven't dynoed the motor yet, I pulled the heads to get some bowl work and back it on intake valves..
As for fuel system,Still need to order a carb, possibly looking at a ultra 950 xp, a refurbished one from the Holley store , as for rest of the fuel system thinking just a Holley 130 gph fuel pump, half inch line with half inch sending unit and a regulator. I think that should be enough??
Hopefully in a month get it dynoed
duff429
duff429
Post  duff429 June 18th 2019, 8:23 pm
Finally the motor is getting dynoed this Friday. I just hope everything goes ok. Any guess on power?
duff429
duff429
Post  68galaxie June 19th 2019, 9:27 am
Engine pics (and car) look fantastic.
Not sure what compression ratio you ended up with or what camshaft specs you ended up with.
Those will give us an idea what rpm range - and what possible HP output will be.
Without much information it is tough to guess.
Could be 400 hp to 750 hp. (baby cam and low compression to big cam and higher compression)
68galaxie
68galaxie
Post  glenevans June 19th 2019, 3:15 pm
x2, thought I missed it somewhere..
glenevans
Post  duff429 June 19th 2019, 4:31 pm
68galaxie wrote:Engine pics (and car) look fantastic.
Compression should be around 10.3. deck clearance is .011, cam is solid cam from Randy 668 lift 649 exhaust 259,265@.50
Roller Harland sharps rockers, intake ported and heads have bowel blend and intake back cut. Pro systems 1000cfm and jomar powercone.and 547 cubic inch 4.400 bore, 4.500 crank. We were going 552 but had to get a different block
duff429
duff429
Post  68galaxie June 19th 2019, 5:47 pm
I would guess at least 650 hp.
Let us know what it does!
68galaxie
68galaxie
Post  glenevans June 19th 2019, 6:50 pm
690 - 710 ......ish
glenevans
Post  duff429 June 19th 2019, 8:13 pm
glenevans wrote:690 - 710 ......ish
That would be nice, but I don't think it I'll be that much. My guess is 668 . Dyno will be at 900 feet elevation vs 5,000 in Wyoming
duff429
duff429
Post  glenevans June 19th 2019, 9:46 pm
Where in Wyoming? They gave me the "correct ed" hp, which accounts for elevation and I believe temperature. I am in Tremonton which is near Logan, Utah. I got a Wyoming elk tag this year, unit 98 I believe.
glenevans
Post  duff429 June 19th 2019, 9:55 pm
Casper. But I work out of town so I haven't been back in 3 months or so
duff429
duff429
Post  Colt Macara June 21st 2019, 12:35 pm
Follow for "Dyno"
Colt Macara
Colt Macara
Post  duff429 June 21st 2019, 1:02 pm
It made 630 hp at 6000 and 670 lb at 4400. I'll post a sheet later
duff429
duff429
Post  rmcomprandy June 21st 2019, 1:19 pm
duff429 wrote:It made 630 hp at 6000 and 670 lb at 4400. I'll post a sheet later
That is all the RPM you will need to use in a regular hot-rod street car.
Post  glenevans June 21st 2019, 1:51 pm
Very nice! That will get you moving
glenevans
Post  duff429 June 21st 2019, 3:48 pm
First 547 build - Page 2 Img_2018
duff429
duff429
Post  Mark Miller June 22nd 2019, 12:03 am
I'm guessing that's a Flat Tappet Solid Cam not a Roller?
Post  duff429 June 22nd 2019, 12:28 am
Mark Miller wrote:I'm guessing that's a Flat Tappet Solid Cam not a Roller?
Yes sir flat tappet
duff429
duff429
Post  duff429 June 22nd 2019, 9:16 am
Yes sir, thanks Randy, cam worked out great
duff429
duff429
Post  rmcomprandy June 22nd 2019, 10:25 am
That cam was designed for a 472 / 502 size engine so, it really should have been about 4 degrees larger but, certainly not enough difference to spend the money for another camshaft.
Post  duff429 June 22nd 2019, 1:02 pm
Out of the 10 pulls one at 32 degrees
it made 675.2 @4500
But horsepower dropped to 626.4 @6,000
It all depends on what I guy wants I guess
duff429
duff429
Post  Mark Miller June 22nd 2019, 11:59 pm
Yes sir flat tappet
Nice numbers from a flat tappet cam!! Smile
Post  duff429 June 24th 2019, 2:20 am
Mark Miller wrote:
Yes sir flat tappet
And its painted for the incognito look
First 547 build - Page 2 Img_2019
duff429
duff429
Post  Mark Miller June 24th 2019, 10:50 pm
duff429 wrote:
Mark Miller wrote:
Yes sir flat tappet
Cool almost looks like a stock 460!! Smile
