First 547 build
+8
duff429
12 posters
First 547 build Empty First 547 build
Post  duff429 February 21st 2018, 2:53 pm
First build finnally , going in a 70 cyclone gt street car
Engine is at machine shop now getting machine work done and balanced. Only requirements are to have stock cobra jet valve covers and fit under stock cyclone gthood should be around 10.3 compression with 72 cc heads
So far here's my parts list
Cast steel 4.500 crank
Icon forged pistons 35 cc dish
6.8 I beams
Mcleod flywheel
Summit racing balancer
Canton -15-750 oil pan
Melling oil pump
Clotes timing chain-
Heads aluminum SCJ - still need to get, possible bowel blend
Cam?? Thought I'd call lem, not sure if I should go hydraulic,solid, etc
Intake???? Thinking a mafia intake??
Headers will be hooker 6201
Was just looking at some other builds here and was gonna  try to duplicate
Feel free to make suggestions
duff429
duff429
First 547 build Empty Re: First 547 build
Post  dfree383 February 21st 2018, 3:10 pm
Hydraulic Roller cam and a Torker 2 intake with a 4150 1050cfm
Post  windsor February 21st 2018, 3:30 pm
Couple of good reads here.
https://www.429-460.com/t21825-521-pump-gas-engine
http://www.460ford.com/forum/45-car-buildup-forum/155108-project-12-99-ltd-finally.html
Post  duff429 February 21st 2018, 4:24 pm
[quote="windsor"]Couple of good reads here.
That's one if the builds I was going off of
duff429
duff429
Post  rmcomprandy February 21st 2018, 4:46 pm
duff429 wrote:First build finnally , going in a 70 cyclone gt street car
6.8 I beams
Mcleod flywheel
Melling oil pump
It won't go under a Cyclone GT hood with a "Mafia" intake manifold.
Personally, I would use a solid flat tappet camshaft with a "Torquer II" intake manifold port matched on cylinder runners 1,3,6,8 ONLY; leave the other runners alone.
Bowl blending or not, be sure to back-cut the intake valves.
Post  duff429 February 21st 2018, 5:38 pm
6.8 I beams
Mcleod flywheel
Melling oil pump
Randy what kinda power would I be looking at if I go that way?
duff429
duff429
Post  rmcomprandy February 21st 2018, 10:55 pm
6.8 I beams
Mcleod flywheel
Melling oil pump
I don't know. I never built one that size but, a 501 with that stuff is over 700 horsepower, if it has a bigger than a street camshaft.
Post  duff429 February 22nd 2018, 1:43 pm
6.8 I beams
Mcleod flywheel
Melling oil pump
Pm sent
duff429
duff429
Post  BBFTorino February 22nd 2018, 3:10 pm
I hope you stiffen up the chassis on that Cyclone. Hate to see such a rare and beautiful car get twisted/pretzeled out of shape!!
Got any pics of the car??
Post  duff429 February 22nd 2018, 3:32 pm
BBFTorino wrote:I hope you stiffen up the chassis on that Cyclone. Hate to see such a rare and beautiful car get twisted/pretzeled out of shape!!
We did subframe connecters from TORES design over at the Torino cyclone site.
Car is still in primer and apart. Decided to get a motor and drive train going
duff429
duff429
Post  BBFTorino February 22nd 2018, 4:53 pm
That is awesome duff!!
Post  Dave De February 24th 2018, 11:39 am
6.8 I beams
Mcleod flywheel
Melling oil pump
My thoughts on the hardware as well. A cool idea to only port match those cylinders to balance the flow distribution I presume. I like a solid flat tappet in an old school car.
As others have mentioned this power requires several drive line upgrades unless you will never go to the track.
Post  duff429 May 18th 2018, 6:50 pm
Just thought I'd update,
Im waiting on a used torker 2 in the mail,will send out for port,
Already got cam from Randy,
Recurved distributer is on its way,
HS s 4073 are on its way,
Probably get a fuel pump from clay Smith cams
Gonna be looking for a set of hooker 6201 soon
And looking for recommendations on a 1050 4150 style carb. Looks like guys like quick fuel carbs?
duff429
duff429
Post  rmcomprandy May 18th 2018, 8:12 pm
duff429 wrote:Just thought I'd update,
The Quick-Fuel "Black Diamond" series #BD-830 double pumper with an electric choke works very, VERY well on a street vehicle.
Post  duff429 May 18th 2018, 9:29 pm
Randy would a 830cfm be enough for my 547 ci ? I'm not too concerned about a electric choke
duff429
duff429
Post  Dave De May 19th 2018, 10:54 am
My experience with my 521 HFT pump gas engine in my Torino. Started with a 750 then went to a 950. The change didnt affect drive ability but the engine was stronger on the top end with a noticeably lower ET. The car ran mid 11's with traction issues but trapped at 120 mph. I remember the 750 mph was lower by at least 2. For some reason I hate the poor signal 850's. I think they are lazy but I dont have data to back that up. A poor signal cannot respond quickly and may lag in the fuel curve.
Holley has done a great job to improve their carbs over the last 5 years.
If its going to be a 4150 stay at 950 maximum. The larger sizes are a compromise but this is my opinion and I am opinionated.
Also I agree on the "no choke" who needs that on any of this? So what if its a little fussy on a cold start. I'll take that over that restrictive choke horn any day.
Post  rmcomprandy May 19th 2018, 11:13 am
CFM "ratings" don't mean much for the actual figures. That carb has a larger secondary venturi than a Holley 950.
It was perfect on a Kaase headed 528 BOSS Hemi; larger and smaller ones were tested.
That particular main body type carb is not available without a choke.
The Q-1050AN is fine if you don't want a choke.
In either case, use a Jomar "Powercone" spacer between the carb and Torquer II manifold.
Post  duff429 May 20th 2018, 3:44 pm
Thanks for all the replies, I know what direction to go now.thank you
duff429
duff429
Post  duff429 January 2nd 2019, 6:38 pm
Well I got my motor back finally, it's now a 552, and I got my car painted
First 547 build Img_2010
First 547 build Img_2011
duff429
duff429
Post  cletus66 January 2nd 2019, 7:53 pm
NICE !!!!! Cool
Post  Mike R January 2nd 2019, 10:43 pm
Love it!!! Those cars always look good in Grabber Blue
Post  duff429 January 2nd 2019, 11:01 pm
Just getting it mocked up but still need to prime, put water pump on , intake,paint head's Ford blue yet..
First 547 build Img_2012
duff429
duff429
Post  Mark Miller January 3rd 2019, 12:02 am
Looking good are those Hooker 6201 Headers? Smile Smile
Post  duff429 January 3rd 2019, 12:34 am
Mark Miller wrote:Looking good are those Hooker 6201 Headers? Smile Smile
Yes sir, 6201, still gotta hole saw the side of engine bay too
duff429
duff429
Post  Mark Miller January 4th 2019, 12:05 am
It sucks you've to cut holes to fit them but you've got to do what you've got to do!!! Smile
