430 piston install
430 piston install
Rebuilding a 430 mel for a 63 Lincoln just got the rings on pistons than realized how the hell do i install the pistons? Do i buy a cheap compressor and cut it to fit the 10 degrees?
slurm- Posts : 103
Re: 430 piston install
Slurm go to the fe technical forum There is a fellow Royce Belcher all he builds are MELs he would have some suggestions for you .Someone on the old fe forum would have some ideas as well .Good luck with the old iron ! Doug:afro:
manofmerc- BBF CONTRIBUTOR
thank you for the direction, got one in using a couple of feeler gauges and a lot of patience. Thinking i should of open up the wedge part of the block a couple of thousands.
slurm- Posts : 103
what you ever figure out? I'm curious how they are installed, never worked on one before.
Used a band style installer. Put it on the piston with long sleeve down, tap on it lightly to seat against top of cylinder. Worked great
slurm- Posts : 103
slurm wrote:Used a band style installer. Put it on the piston with long sleeve down, tap on it lightly to seat against top of cylinder. Worked great
Yes ... the top angled deck was counterbored on the 430 I worked with so, there was a fine ledge for the band type ring compressor to butt against.
I don't know if all the MEL blocks were like that.
» Piston ring install lube
» Anyone know how close the Forged L2366f piston is to cast 429 piston?
» Fox 460 install
» Cam Bearing install
» old syle aluminum cj heads
» Fox 460 install
