4 digit pump gas power ??
+23
torino501
Colt Macara
57ford custom
manofmerc
wayney
jeffgfg
D. Sea
AZFairlane
rmk57
Bosskk1786
27 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: 4 digit pump gas power ??
598... it is what it is.....make it up in spray if you're not happy
Nick I know where I think is a 68 I go by this weekend and get some pics of it.pm me your number and I text you some pics of it. It is not as nice as the one you are looking at but it will not cost as much either.
dfree383 wrote:598... it is what it is.....make it up in spray if youre not haopy
just want it faster then the Shelby, which i have no doubt on that, with the starting weight of this car and going auto. With also running low 6 or high 5s in the 1/8
bruno wrote:Lem Evans wrote:windsor wrote:This is with a stock block. https://www.429-460.com/t14610-dyno-results-a-headed-557-on-91-octane-pump-gas-dyno-update-page-6
And Bill Fowler (CDMBill) has done it with a 589” with extensive Drag Week use. TFS tunnel ram with dual EFI throttle bodies and Megasquirt. 1014 hp several years ago.
https://youtu.be/msBeVfZgP-Q
That's not a $15,000 or under engine.
the 589" deal certainly isnt , but the 557 looks like a budget deal ? just dont know how accurate that dyno is , seems really impressive for 91 octane ....
Bill's stuff is the real deal.
bruno wrote:this is the car im working on now to acquire.
Nice looking car Torino or Fairlane my dad sold a 68 Torino GT years back only had a 302 in it though!!!BBF is going to be a tight fit in there with the factory shock towers it will fit with the shock towers but changing the plugs will be a bear!!!!
Mark Miller- Posts : 1958
Actually, its not that bad. It is easier to change the plugs on a 385 series in these chassis of cars, than it is when they have an FE in them.Mark Miller wrote:bruno wrote:this is the car im working on now to acquire.
The biggest hurdle is depending on what type of valve covers the engine has on it.
Remove the valve covers and it is quite simple really.
BBFTorino- Posts : 999
The front subframe is the same as 70/71 Torino or Cyclone...of which 429's were factory options.
recently sold my 68 TORINO/ FAIRLANE that I had installed a 429 in. FUN CAR
BOSS 429- Posts : 2372
Nick,
Love the car, I had a 69 R code Ranchero that I wish i hadn't sold...
That said, I was younger and dumber and absolutely HATED working on the car because of those damn shock towers. Decided to build a car that was easier to work on and have had the same car ever since. Started building it in '94
Who was it that had the Green 65-66 Galaxie? Would love to have that car!!!!
D. Sea- Posts : 2768
D. Sea wrote:Nick,
So you guys are really making me second guess this decision about these cars because of the shock towers !!
bruno wrote:D. Sea wrote:Nick,
Galaxie or Merc...
I'm sending you a PM
Its not that bad, Worst case you can notch them like a Boss 9 mustang.
dfree383 wrote:bruno wrote:D. Sea wrote:Nick,
Anyway you slice it, even with notched shock towers headers are going to be compromise with a 1000 hp engine in that compartment. Not to mention cutting a big hole in the hood for cold air.
I suppose you could run cold air through the inboard headlights, but you would still need a scoop of some sort to hide the carburetors.
It looks like a real nice car and I'd be a little reluctant to start modding it like you would have to. On the other hand, there not rare, they made a ton of them.
rmk57- Posts : 176
Biggest issue with the shock towers is header fitment....the rest you can work around. Very nice car I would like to put a 385 in it as a fun street car, like Rich's !!
jeffgfg- Posts : 338
bruno wrote:dfree383 wrote:598... it is what it is.....make it up in spray if youre not haopy
low 6 or high 5s should be no problem with spray and a conventional p51/afr head and spark plugs will be much easier to change.
wayne
wayney- Posts : 187
Not talking you out of anything, if your looking for plug and play with a 1000+ it will be easier with a 72+ in the Torino body being a full frame, you can cut away on that one as it will be really cool, regardless of what some say we are beating up on the shock towers because likely you wont be happy with them intact. However, I am sure you already know that, and the likelyhood you will rip that unibody in half with a 1000+hp and no chassis work IMO is high. My guess is you planned on doing some cutting and bracing anyway and a concours purist I am not. So if that is what you want I say go for it cut that bitch up, stuff a monster BBF bullet in it, run pump gas, and enjoy the Fuc$ out of a mostly factory appearing street monster that get's it done!
FalconEh- Posts : 1448
472 with a pro charger will get you where you want to be. Plus you can use a lower profile intake manifold and less exotic cyl heads. I think your budget # of 12-15K is low either way.
stanger68- Posts : 500
FalconEh wrote:bruno wrote:D. Sea wrote:Nick,
No doubt i appreciate everyone's input , just want to do this project as stock looking as possible , especially keeping every thing under the stock hood, which looks like it will be my biggest hurdle.
The good news is with the correct backspace you can squeeze on a 275 /60/ 15 tire without cutting anything. Have your GT wheels widened and adjusted for B/S and it would look pretty good.
rmk57- Posts : 176
rmk57 wrote:The good news is with the correct backspace you can squeeze on a 275 /60/ 15 tire without cutting anything. Have your GT wheels widened and adjusted for B/S and it would look pretty good.
Yes exactly what i would like to do
IIRC aren't those chrome GT wheels 14"?
D. Sea wrote:Who was it that had the Green 65-66 Galaxie? Would love to have that car!!!!
I think it was a friend of Travis Rice. That car was sweet!
jbozzelle- Posts : 3705
Just think of changing plugs in you old gray Mustang. They were a pain. Shock towers on the older cars are a real pain...
Chase after the full frame cars for your build..
shock towers
Those shock towers can be cut back .If it is done right you cant really see it .Cutting the towers back makes plug changes easier as well as header installation The headers from Crites will fit without cut back towers BUT it is much easier to install all those pipes after a slice and dice .I have been doing so with both my 66-67 comet one with a 460 and the other a 427 .Cool cars but somewhat difficult to work on at times .Doug
manofmerc- BBF CONTRIBUTOR
Damn shock towers !!
» Power steering pump
» Power loss of mech fuel pump?
» 69 460 remove power steering pump?
» Looking for pics of engine plate with power steering pump
» WTB: Power steering pump and bracket setup for a 460.
Page 2 of 4
