Little off topic...E40D in a drag car...
Anybody done this in a street/strip car? Plenty of real estate for the trans to fit with a square tube chassis. Is this a viable option for 572 cubes (NA and eventually boosted) and 3500+ pounds?
cletus66- Posts : 865
Re: Little off topic...E40D in a drag car...
It's a big heavy SOB that needs a computer of some sort (stock EEC-IV ECM, diesel pickup trans controller or a $$$ stand alone controller) to make it work properly. Converters are pretty dang expensive too.
This guy built his own stand alone controller with the intent of offering it as a kit, but his interest has since waned.
https://www.ford-trucks.com/forums/1216737-e4od-operation.html
If I wanted overdrive, I'd do a C6 + Gear Vendor or a glide + GV.
BigBlockRanger- Posts : 1267
Thanks, that's the impression I was getting while searching around the interwebs.
Baumann makes a stand alone controller for the e4od.... I would say check out nloc.net for some ideas... Lots of 1st Gen lightnings making lots of power with that tranny behind them... I got a 2500 stall converter with lockup and an anti balloon plate for about $580 from monster transmission..... Not a bad price I thought.... And a punisher valve body
Bosskk1786- Posts : 96
Good to know.
Bosskk1786 wrote:Baumann makes a stand alone controller for the e4od.... I would say check out nloc.net for some ideas... Lots of 1st Gen lightnings making lots of power with that tranny behind them... I got a 2500 stall converter with lockup and an anti balloon plate for about $580 from monster transmission..... Not a bad price I thought.... And a punisher valve body
Thanks. I'll check that out.
I've contemplated building one of those for my '79 pickup for a long time and a friend of mine has the right core with the cable speedometer provision. I think that the E40D would be much better than a C6 with a Gear Vendors OD simply because it also has a lock up converter. My truck has 4.10 gears and it would benefit greatly from an overdrive.
DaveMcLain- Posts : 399
DaveMcLain wrote:I've contemplated building one of those for my '79 pickup for a long time and a friend of mine has the right core with the cable speedometer provision. I think that the E40D would be much better than a C6 with a Gear Vendors OD simply because it also has a lock up converter. My truck has 4.10 gears and it would benefit greatly from an overdrive.
This article about doing just that is what started to make me wonder how it would work in a big ol' tubbed out '66 Galaxie:
http://www.hotrod.com/articles/1105cct-1973-ford-f350-e40d-transmission-swap/
We retrofit an EFI7.5L/E4OD into our 73 truck. It was a PITA to get it to work properly mainly because we had to come up with a way to get a speed signal to it. Ours does not have a speedo drive in it, so we had to pull our speed signal from a front wheel ABS sensor. (Crown Vic front suspension)
Trans works good and shifts great after we put a Punisher valve body in it. But, it is huge and heavy and will likely require floor pan surgery. Ok for a truck, but I don't think I would put one in a street/strip car unless it was a big car.
BigBlockRanger wrote:We retrofit an EFI7.5L/E4OD into our 73 truck. It was a PITA to get it to work properly mainly because we had to come up with a way to get a speed signal to it. Ours does not have a speedo drive in it, so we had to pull our speed signal from a front wheel ABS sensor. (Crown Vic front suspension)
It's a big'un. '66 Galaxie with a full tube chassis and currently no floor from the firewall to the back bumper. Otherwise, I wouldn't even consider it.
cletus66 wrote:DaveMcLain wrote:I've contemplated building one of those for my '79 pickup for a long time and a friend of mine has the right core with the cable speedometer provision. I think that the E40D would be much better than a C6 with a Gear Vendors OD simply because it also has a lock up converter. My truck has 4.10 gears and it would benefit greatly from an overdrive.
Good article thanks for the Hot Rod link!!!
Mark Miller- Posts : 1954
Didn't Greg Pettit have one in his yellow 70 Torino over on the other site? I remember Jon Faubion (Fabio) building it possibly. It's behind a 545 and runs in the 10's and holds up well...
jbozzelle- Posts : 3705
» E40d Tranny Pan with C6
» Off topic 400 M
» Off topic but Ford
» AFR Head topic
» e40d trans in a motorhome 1997 F53 chassis with a 460???
» Off topic 400 M
» AFR Head topic
