Need heat
Need heat
I'm running a motorsport victor intake and wonder what is done for a heater hose and temp sensor connection
quick 52- Posts : 612
Re: Need heat
quick 52 wrote:I'm running a motorsport victor intake and wonder what is done for a heater hose and temp sensor connection
Go to the post pictures of your engines thread click on the last page and a picture of my Mark Miller's engine I have a Victor Intake and have heat and Temp gauge[look at the top of my thermostat housing in my picture]!!
Mark Miller- Posts : 1959
Re: Need heat
Was looking at that housing have the same one on my engine. Was thinking that the temp. sensor wouldn't work till the stat open are you drilling the stat. Thanks for the pic have about the same engine 472 A429 heads victor motorsport with a 950 hp solid FTMark Miller wrote:quick 52 wrote:I'm running a motorsport victor intake and wonder what is done for a heater hose and temp sensor connection
Re: Need heat
quick 52 wrote:Was looking at that housing have the same one on my engine. Was thinking that the temp. sensor wouldn't work till the stat open are you drilling the stat. Thanks for the pic have about the same engine 472 A429 heads victor motorsport with a 950 hp solid FTMark Miller wrote:quick 52 wrote:I'm running a motorsport victor intake and wonder what is done for a heater hose and temp sensor connection
I have a 160 degree thermostat now had a 180 before no holes in the thermostat's I run them the way I buy them no modifications!!! The temp gauge usually starts out reading 150 degrees after it runs for a little while!!
Re: Need heat
It works fine . I've done it too.
gt350hr- Posts : 662
» Heat....
» spark plugs for 466 with 14 to 1 comp
» Help controlling engine temp
» Cheap Ignition
» The Heat is On
» Cheap Ignition
» The Heat is On
