balancer problem
balancer problem Empty balancer problem
Post  o henry May 1st 2018, 6:55 pm
ok bought this 514 turn key.. need to change balancer old one measured 6.25 with tape measure....picked up new one is 6.76 diameter ..now factory timing pointer is 10 degrees advanced ..yes we are on tdc.. called ordered adjustable one from suppler they told me i needed an ati 918945..told them i had msd crank trigger 8644..recieved pointer will not work ...i am at a loss..ready to send it all back or go rogue and cut factory pointer long ways mark it and have it welded or brazed up... so heres all part numbers thru jegs...balancer is 555-51634 pointer is 085-918945...i am at a loss. i think old balancer might have been a summit ??
o henry
balancer problem Empty Re: balancer problem
Post  rmcomprandy May 1st 2018, 7:30 pm
o henry wrote:ok bought this 514 turn key.. need to change balancer  old one measured 6.25 with tape measure....picked up new one is 6.76 diameter ..now factory timing pointer is 10 degrees advanced ..yes we are on tdc.. called ordered adjustable one from suppler they told me i needed an ati 918945..told them i had  msd crank trigger 8644..recieved pointer will not work ...i am at a loss..ready to send it all back  or go rogue and cut factory pointer long ways mark it and have it welded or brazed up...  so heres all part numbers thru jegs...balancer is 555-51634  pointer is 085-918945...i am at a loss. i think old balancer might have been a summit ??
Make one ...
Post  o henry May 1st 2018, 9:24 pm
yep came to that idea.. tired of fooling with it thanks
o henry
