2018 F150 Auto Start/Stop Tech
+10
nickbay
QtrWarrior
14 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: 2018 F150 Auto Start/Stop Tech
If I had a new truck I would not use a tune to turn it off. The tune may void the powertrain warranty if Ford detects a tune (maybe)
Easiest fix is what Big Block Ranger posted.
A simple plug into the trailer connector will cause the truck to detect it has a trailer hooked up and it will automatically disable the start/stop.
All it has to do is detect a small light bulb drawing power thru the trailer connector
BigBlockRanger wrote:Work around: I think you can plug a trailer light tester in the trailer light connector and the truck will "think" it has a trailer attached and that disables the stop/start.
83-88T-Bird Guy- Posts : 1003
Maybe I should buy some of these 4 pin connectors and wire in a small light bulb and sell them as the cure for the start/stop.
I'll be rich.....lol
https://www.bing.com/videos/search?q=F150+auto+start%2fstop+delete&view=detail&mid=C08A5E907B6AF8423DD4C08A5E907B6AF8423DD4&FORM=VIRE
dfree383 wrote:https://www.bing.com/videos/search?q=F150+auto+start%2fstop+delete&view=detail&mid=C08A5E907B6AF8423DD4C08A5E907B6AF8423DD4&FORM=VIRE
Thanks for the link don't know if i'll do it or not but i'll click on this link if I ever decide to!!!
Mark Miller- Posts : 1959
made a few hits on the 5.0 F150 at the Bash
In the heat ran a 9.20 @ 78.25 mph, Need to get a few hot rod parts now........
Lem Evans wrote:Was it in stop or start when you made the pass?
No I hit the switch...... it would be a second or two slower if it was on.....
dfree383 wrote:made a few hits on the 5.0 F150 at the Bash
Nice my bone stock daily driver 2017 Super Crew 4x4 XL STX with 3.5L Eco Boost 10 speed automatic and Max Tow Package ran a 9.222@76.68 mph and a 9.235@76.44 mph in the 1/8 mile 14.323@96.21 mph and 14.334@96.41 mph in the 1/4 mile!!:)2 wd or 4wd truck?
Mark Miller wrote:dfree383 wrote:made a few hits on the 5.0 F150 at the Bash
4x4 Super Cab 5.0 with the 10 speed
dfree383 wrote:Mark Miller wrote:dfree383 wrote:made a few hits on the 5.0 F150 at the Bash
I wander how much lighter your truck is than mine 2-400 pounds maybe?
Stephen ran a best of a 9.29 @ 77 with my 2wd crew 2.7eco .....
bruno wrote:Stephen ran a best of a 9.29 @ 77 with my 2wd crew 2.7eco .....
If I could get my 2017 Super Crew 4x4 with the 3.5L Eco Boost and 10 speed to 60 ft like the 2.7L Eco Boost truck I had I could probably run 14 teens or 14.20's in the 1/4 mile instead of 14.30's!!! Nick what year is your truck 6 speed automatic or 10 speed automatic?
Mark Miller wrote:bruno wrote:Stephen ran a best of a 9.29 @ 77 with my 2wd crew 2.7eco .....
2015 2wd crewcab with 80k miles
bruno wrote:Mark Miller wrote:bruno wrote:Stephen ran a best of a 9.29 @ 77 with my 2wd crew 2.7eco .....
Damn if you bought that truck new you must drive a lot!!!
Mark Miller wrote:bruno wrote:Mark Miller wrote:bruno wrote:Stephen ran a best of a 9.29 @ 77 with my 2wd crew 2.7eco .....
yes i did, traveling between my 2 stores put alot of mileage on her.
Lem Evans wrote:dfree383 wrote:Lem Evans wrote:dfree383 wrote:Anybody deal with this BS yet? How do I eliminate it? What software can I get?
There is a damn button you push on the dashboard to turn it off.
I don't want to push a freaking button every time I start the truck
You'll have to turn a key or push a button if you want to start a vehicle. You'll have to turn a knob if you want to turn the radio up or down. You'll have to flip a switch if you want the heater to blown......just warning you.
That would require him to wake up and get out of his recliner.... I think your asking alot here Lem...
To get this thread back on topic you can use Forscan to turn off the auto start/stop function. Good friend just did it with his new F150.
jbozzelle- Posts : 3705
jbozzelle wrote:To get this thread back on topic you can use Forscan to turn off the auto start/stop function. Good friend just did it with his new F150.
Just started checking this out, looks pretty cool with the Bluetooth plug in OBD module and working on a IPhone.
Friend has been using it for some time and likes it. Going to check it out myself.
IDK about Apple but the Android version is Forscan lite and doesn't seem tp do as much as the windows version. I have the OBDLink MX Bluetooth and use the bluetooth on my laptop.
http://www.obdlink.com/mxbt/
https://www.amazon.com/gp/product/B006NZTZLQ/ref=s9_psimh_gw_p263_d3_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0FDJ7ETZ3DC8DSKYGSP2&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846&tag=scantonet-20
https://forscan.org/download.html
One thing I have found is lots of times it won't connect to your device if you just looking at bluetooth connections but if you open Forscan and hit connect it finds the device every time.
jasonf- BBF CONTRIBUTOR
It's actually euro standards required, the EPA liked and picked it up. Ive been dealing with it since 14, it's very finicky on parameters to work
Depending how the ford system works, does it use a second battery for the restart, if so, disconnect that battery, and system stops working, may or may not turn the light for eco on the dash.
litshoot- Posts : 103
litshoot wrote:It's actually euro standards required, the EPA liked and picked it up. Ive been dealing with it since 14, it's very finicky on parameters to work
Only one battery in the F-150's!!
damn, is there a separate module that has a capacitor in it. We've gone through 4 different system, 2 of which we could disable by either disconnect the battery, or it was a stand alone module we disconnected. First 3 years of the having it every one wanted it gone, now everyone keeps saying it wont work. Can't win with customers
Page 2 of 2 • 1, 2
» 2018 Mustang Cobra Jet
» 2015 F-150 Goes to Start Stop Technology Eco-Boost
» PRI 2018
» Lem when will the 2018 Mustangs be out??
» Rocky Mountain Race Week 2018
» PRI 2018
Page 2 of 2
