Comp Cams Valve Lash
+8
Albert Clark
DaveMcLain
valvemotion
Ol Yaller 73
12 posters
Got a question. I have an iron head 460, running a Comp Cams 294B-8 solid flat tappet cam. Stainless valves. Roller Lifters.
The lash recommendations are.030 intake and exhaust. This seems a little big. Anyone running this? What would you set them at?
Thanks!
Thanks!
Ol Yaller 73- Posts : 3
Re: Comp Cams Valve Lash
I don’t like them that loose, I’d try .020-.022
dfree383 wrote:I don’t like them that loose, I’d try .020-.022
x2
BOSS 429- Posts : 2372
Ol Yaller 73 wrote:Got a question. I have an iron head 460, running a Comp Cams 294B-8 solid flat tappet cam. Stainless valves. Roller Lifters.
Thanks!
That cam is designed with a .0175" lash ramp on the lobe so, .030" is the maximum HOT valve lash which should be run when using a 1.73/1 rocker arm.
I would set them wherever it runs the best between .012" and .030"; intake and exhaust do not need to be the same.
rmcomprandy wrote:Ol Yaller 73 wrote:Got a question. I have an iron head 460, running a Comp Cams 294B-8 solid flat tappet cam. Stainless valves. Roller Lifters.
Thanks!
I agree 100%
I've run mine at .012 and .014 intake/exhaust (hot) because the loose lash tents to beat the crap out of the pushrod ends!!
BBFTorino- Posts : 999
BBFTorino wrote:I've run mine at .012 and .014 intake/exhaust (hot) because the loose lash tents to beat the crap out of the pushrod ends!!
If you stay on the intended lash ramp of that lobe profile, the contact velocity of a flat tappet cam will remain the same 99% of the time. It just takes less duration from there to get going faster up the ramp, sooner.
rmcomprandy wrote:BBFTorino wrote:I've run mine at .012 and .014 intake/exhaust (hot) because the loose lash tents to beat the crap out of the pushrod ends!!
That's right most solid lifter cams have a constant velocity ramp for that very reason. On some old factory cams this area can be pretty long which should make the lash setting very forgiving in that some valves could be quite a bit looser and not make any more noticeable noise than one set significantly tighter. With this type of cam setting the valves tighter really doesn't do anything except add some duration.
Where most people screw up is with what to do with the lash when changing the rocker ratio. Since the lash setting happens at the valve it should be increased as the rocker ratio is increased to keep the contact points on the ramps (duration) the same.
DaveMcLain- Posts : 399
Thanks!
The question is why are you running a solid lifter camshaft with Roller lifters?
Albert Clark- Posts : 72
Albert Clark wrote:Ol Yaller 73 wrote:Got a question. I have an iron head 460, running a Comp Cams 294B-8 solid flat tappet cam. Stainless valves. Roller Lifters.
Thanks!
Albert is the only guy with a keen sense for the odious
Thanks!
YES ... that fact went un-noticed.
That sure should not be done ... ever.
I just figured he said "lifters" when he meant "rockers". He had just stated he had a solid flat tappet cam.
Maybe he can come back on here and clarify - oops or BIG OOPS.
pmrphil- Posts : 171
How about running roller pushrods with your solid rockers and plastic lifters??
BBFTorino wrote:How about running roller pushrods with your solid rockers and plastic lifters??
Let me ask you something? You just come on here to flap your lips and or to hear yourself don't you?
some of the things you spout off make as much sence as going to a proctologist to have your teeth worked on
Yours Truly Albert
Albert Clark wrote:BBFTorino wrote:How about running roller pushrods with your solid rockers and plastic lifters??
Yours Truly Albert
OUCH
Dave De- Posts : 797
Thanks!
Good catch. I have the same cam and I even did not snap to the roller lifters and had to do a double take.
Guess it will take a bunch of the lope out with roller lifters, LoL.
supervel45- Posts : 4499
rmcomprandy wrote:Albert Clark wrote:Ol Yaller 73 wrote:Got a question. I have an iron head 460, running a Comp Cams 294B-8 solid flat tappet cam. Stainless valves. Roller Lifters.
Thanks!
Good catch on the lifters... I've seen that done a few times and one that I can think of was on a Chrysler 2.5 overhead cam engine that came in with a noisy valvetrain. They were known to break a cam once in a while out near the middle. This must have happened to this engine one time or another and somebody changed the cam but used the one for the non roller followers! The rollers wore a groove close to 1/8th inch in the lobes and put a bunch of crap into the engine but after swapping on the right cam it ran once again.
.030 Lash and Lifters
OOPS, I meant roller ROCKERS, not roller LIFTERS. Thanks to all the sharp eyes out there! I stand corrected.
» Comp cams Valve spring help
» New Comp Cams 999-16 Valve Springs
» Valve lash
» Comp Cams valve springs
» SBF valve lash (mechanical cam)
» Valve lash
