Getting the parking brake cable out of the backing plate......
Last edited by JBR-3 on September 20th 2020, 1:54 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Re: Getting the parking brake cable out of the backing plate......
I find it easier to remove the cable by using a hose clamp to close the "fingers" of the parking brake cable's ferrule that locks it into the backing plate. Once the closed "fingers" just make it through the plate, I remove the clamp and the cable assembly is then easily removed. Hope this helps.
aquartlow- Posts : 169
If you don't have a clamp small enough you can just use pliers to compress a few of them, turn the cable at an angle to get those fingers started then turn a little and do it again till all the fingers are through.
jasonf- BBF CONTRIBUTOR
put a 1/2" box end wrench on it and rotate back and forth it will pop right out
Frank Merkl- Posts : 1524
Last edited by JBR-3 on September 20th 2020, 1:55 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Frank Merkl wrote:put a 1/2" box end wrench on it and rotate back and forth it will pop right out
I have read that before and forgot all about it.
20 years on the bench ! you learn a few tricks !
» 73 mustang parking brake cable routing
» Water pump backing plate
» Water pump backing plate thickness?
» Meziere electric water pump with backing plate
» ford 9 inch part needed
