460 block
460 block
This is a 90's model block that is clean and bored .030 over and ready to be used. Made a mistake thinking my old stock 60's crank would work and would not. Ready for your crank and internals. Make me a offer. Thanks 423six one eight 2516
cobrakid8- Posts : 288
Re: 460 block
I ran into the same problem trying to install the rotating assembly from D1VE into a D9TE block. But by careful grinding in the block, I was able to install the early rotating assembly in the late block. This was done several years ago, and have had zero problems with it.
Wayne (SAWDOFF) Pearce
Last edited by Wayne Pearce on August 21st 2018, 12:09 pm; edited 1 time in total (Reason for editing : forgot to sign)
Wayne Pearce- Posts : 658
different crankshaft
Some people grind the oil guard down to clear.
ED468- Posts : 200
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» 540 Long block / Boss9 block / AR CJ cylinder heads - $3300 OBO
» New 57 Ford Project Should we go big block or small block? Pics added
