OEM Main Bolts
OEM Main Bolts
Do any of the vendors sell OEM main bolts?
wickettoby1- Posts : 352
Re: OEM Main Bolts
Okey dokey, I’ll have to get some dimensions and see what I can find. Thanks Lem
Re: OEM Main Bolts
Lem
With a new grade 8 bolt do you just use the OEM torque sequence and specs? I don’t have a rig or the equipment to measure the torque to get proper bolt stretch.
Re: OEM Main Bolts
If you need main bolts for a dime-a-dozen 2-bolt block build, then these black-oxided Grade 8 bolts should suit you fine:
2 packages (enough for a block) will set you back about $20 shipped. They may be found by clicking here:
https://www.mcmaster.com/#92316a729/=1ecau4p
Re: OEM Main Bolts
Thanks for the link Paul
» Main Bolts
» Main studs or Bolts
» WTD; Need a set of stock main brg bolts, Dove, 2 bolt block
» main bolts or studs or not......
» main bolts w the stud for oil pump.......
