cnc ported A460 heads
drksyde64
Hello people in the know,
I would like too know your opinions on who has the best cnc program for the money on a set of 18 bolt A460 heads that would be going on a 4.6 bore with either a 4.3 to 4.5 stroke engine between 13 to 14 to 1 compression rpm limit around 7500 using a single carb. Thanx in advance.
Last edited by drksyde64 on March 29th 2019, 9:03 pm; edited 1 time in total (Reason for editing : Please remove this post)
drksyde64- Posts : 12
68formalGT- Posts : 865
Re: cnc ported A460 heads
drksyde64 wrote:Hello people in the know,
IF you haven't bought heads yet ... buy them from Keith Fulp already CNC'd. With the intake to match.
rmcomprandy wrote:drksyde64 wrote:Hello people in the know,
https://www.429-460.com/t16558-keith-fulp-s-618-a-head-interceptor
If your going to do big heads do at least the 4.500 stroke and get the squeeze up 15:1
Lem Evans wrote:68formalGT wrote:BES
He said "for the money" how much money BES be?
He also said best too so I guess that is subjective.
http://www.besracing.com/cylinder-head-and-intake-packages/cylinder-heads/ford/bbf/bes-tfs-a460-heads
BES quoted me $1400 . clean, CNC, valve job, surface deck . not sure how that compares to others.
wayne
wayney- Posts : 187
wayney wrote:Lem Evans wrote:68formalGT wrote:BES
wayne
Doesn't sound too bad! Its probably not the Wayde Mahone port job but I bet it's good.
Tony Bischoff
If you want to go the the next level like the Wade Mohoney stuff, Tony Bischoff is the man.
Gary Blair- Posts : 221
» Ported my D0VE-C heads
» Cometic MLS head gaskets
» question on compression ...using pump gas (a460...using fms a460 heads)
» Ported heads
» Question about TFS A460 and Motorsport A460 heads
» Ported heads
