Ford F100 1966
Helitractor
Boss9F100 likes this post
Re: Ford F100 1966
Thxs mate...525cid with all the Edelbrock goddies on it. balanced and runs like a dream..
Re: Ford F100 1966
Welcome aboard. Is it hard to find parts there? Post some more pictures as well please.
jasonf- BBF CONTRIBUTOR
Re: Ford F100 1966
Welcome, beautiful truck, what color is that?
Mike R- Posts : 1381
Re: Ford F100 1966
Parts we imported all from the USA . As for the colour im not sure what is its name but will ask my painter as we went thru hundreds of paint samples .
Ran KB pistons at 9.6-1, edelbrock alum heads, Harland sharp roller rocker arms, crower 3/8 push rods, edelbrock preformer cam, lifters , double row timing chain , msd ignition set up, ederlbrock 750cfm carb, edelbrock high flow water pump, ford racing high volume oil pump and oil pan, edelbrock preformer intake etc etc etc ....then ran a E40D o/d auto tranny and had the guy at HGM electronics build the wiring harness for the tranny and used my smart phone via bluetooth to set box up....works like a dream...no vacuum to change gears, no kick down cables.
Truck runs very well , running 3.27 LSD axle on 275/45/20 and does 1940rpm at 75mph...peak torque/hp at 2500rpm as per edelbrock dyno chart
Re: Ford F100 1966
yip, still running it in so havn"t given it a real hard run but its got way more than i need...
» 1966 Ford Fairlane F/S
» Vintage 1966 427FE Eye Candy and Ford Advertisements
» 1966 Ford Fairlane (no engine/trans) ***SOLD***
» 1966 mercury comet/ford fairlane drag
» anybody swapped a 460 in a 77 ford f100
