289 block
289 block
Removing a 289 from a 65 comet that had been restored to install a 427 crate. The block number is c5ae-6015e. Wondering if this block is valuable in general or just to this car. Was going to purchase the engine for 600 now customer wants alot more thinking is a hipo block. No spring pockets in heads and small damper.
slurm- Posts : 103
Re: 289 block
Nope, its just a regular 289, nothing special. Although check to see if it is a 5 bolt bellhousing deal instead of 6.
BBFTorino- Posts : 999
Re: 289 block
Slurm check the main caps,if they are the same thickness from top to bottom they are hi po if they start out wide at the block and then neck down narrower about 2/3 of the way up then there standard.That's really the only difference between the standard and hipo block,they even use the same casting as some standard blocks and fitted them with the wider caps hence the claim that it is a hipo.No spring pockets and skinny balancer points toward non hipo but you never know what got swapped around.
427John- Posts : 86
Re: 289 block
A C5AE-E is a 6 bolt block and was common to BOTH lo po and hi po. ONLY the main caps were different. Once the block casting number was put into print and spread all over the internet, EVERY block became a HiPo block. $100 block to someone who cares about dates. many use later blocks thinking the cylinders are longer for the 302 stroke.
gt350hr- Posts : 662
Re: 289 block
thanks for the info. Many a tire kicker stop by to pull a valve cover and say they are going to buy it. Then crickets.......
slurm- Posts : 103
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» 540 Long block / Boss9 block / AR CJ cylinder heads - $3300 OBO
» New 57 Ford Project Should we go big block or small block? Pics added
