Block decking
The Pope
OldRedFord
Block decking
Do I have to have the bottom end with all 8 pistons in the block to have a machine shop 0 deck the block?
Also what would my c/r be with d3 heads and factory dished pistons and 0 deck, D1VE block.
OldRedFord- Posts : 465
Re: Block decking
Just need four of them (1-4-5&8 ). Basically just the ones in the corners. I'm not sure about what your cr will be.
Last edited by The Pope on December 21st 2009, 7:04 pm; edited 1 time in total (Reason for editing : 8 ) not 8))
The Pope- Posts : 126
Re: Block decking
WWW.diamondracing.net has the best comp ratio thing that I have seen...it's on the home page .
Re: Block decking
Heres a good one too.
http://www.rbracing-rsr.com/compstaticcalc.html
95lightiningguy- Posts : 570
Re: Block decking
The Pope wrote:Just need four of them (1-4-5&8 ). Basically just the ones in the corners. I'm not sure about what your cr will be.
I think it would be best to take them all 8... as there is bound to be 1 short and 1 long rod piston combination, and it would suck to have taken the 4 shortest/longest ones and find a couple in/out of the hole more than you expect.
If you are going to pony up for balancing, they will need all 8, balancer and flexplate/flywheel also. Save the fuel money making several trips, imo.
longroofracer- Posts : 250
Re: Block decking
Personally, I don't know of any shop that can/will deck a block with the pistons installed. Block must be neked as the setup is off the main bearing bores.
Re: Block decking
Got me there Chuck... lol. Didn't see the "installed" part.
Re: Block decking
I think that by installed, he meant so that the measurements could be taken and then they would be pulled out.
Point taken longroofracer, having all of them in would let the machinest measure all of the cylinders. But if there's differences in the overall lengths of the piston/rod assemblies, the machinest would either (hopefully) ask if you'd prefer that he'd use the longest, shortest or an average. Depending on the application in or out of the hole might work better. I'd think out of the hole would be better and adjust the quench area by selecting a head gasket that would give the amount of clearance needed for the application.
Re: Block decking
The Pope wrote:I think that by installed, he meant so that the measurements could be taken and then they would be pulled out.
Thats what I meant. Sorry about not being clear.
» Decking block
» Decking the block ?
» Block decking
» Decking a block to shorten stroke and lessen the rotating inertia
» Differences between stock type block and the a460 block?
» Block decking
