Decking a block to shorten stroke and lessen the rotating inertia
4speed390
Decking a block to shorten stroke and lessen the rotating inertia Empty Decking a block to shorten stroke and lessen the rotating inertia
Post  4speed390 August 28th 2024, 2:57 am
I have a sort of hypothetical/theoretical question...Has anyone decked a standard BBF block (could be a D0VE, D1VE or D9TE block) down from the stock height of 10.32 to closer to what the BBC might have for example at 9.8?  If not, what is the limit, if someone has tried, to how far one could deck a BBF block and have it still be robust enough for racing?
4speed390
Decking a block to shorten stroke and lessen the rotating inertia Empty Re: Decking a block to shorten stroke and lessen the rotating inertia
Post  dfree383 August 28th 2024, 7:49 am
No real return for the effort IMO
Most your going to get is .200ish again IMO
Better to add rod length to get much lighter pistons.
Another option is an A500 block or I believe eliminator block have a lower deck option.
Mark Miller and Dave De like this post
Post  rmcomprandy August 28th 2024, 10:32 am
4speed390 wrote:I have a sort of hypothetical/theoretical question...Has anyone decked a standard BBF block (could be a D0VE, D1VE or D9TE block) down from the stock height of 10.32 to closer to what the BBC might have for example at 9.8?  If not, what is the limit, if someone has tried, to how far one could deck a BBF block and have it still be robust enough for racing?
A block may accept a .140" cut before you begin milling into the upper bell-housing bolt holes.
It definitely does not have a thick enough deck to accept a .500" cut.
QtrWarrior and Mark Miller like this post
Post  Paul Kane August 29th 2024, 12:40 pm
4speed390 wrote:...Has anyone decked a standard BBF block (could be a D0VE, D1VE or D9TE block) down from the stock height of 10.32 to closer to what the BBC might have for example at 9.8?
The passenger car block's deck is not that thick and you'd be in the water jacket.
QtrWarrior likes this post
Post  BBFTorino August 30th 2024, 2:52 am
Personally, I think the Chevy 9.8 deck is a disadvantage in most cases. For something of the Pro Stock level of build, I can understand it (even the Ford A500 short deck block was meant for Pro Stock), but I think the taller deck Ford does just fine as is.
Post  AndyF September 13th 2024, 4:08 pm
Pro Stock guys did this back in the old days before they had access to race blocks. They shortened the deck height as much as possible while also raising the heads and rotating the valve angle. They wanted a short deck height and bigger bores so they could spin the engine harder. But it took a ton of work and boat load of money to do all of that work. Not really practical to do these days.
AndyF
